05-09-2017 08:46 PM - edited 03-05-2019 08:30 AM
Hi Network 10.1.1.0/31 includes two routes 10.1.1.0/32 and 10.1.1.1/32
People often use these two in production. I remember the first one is subnet and second one is broadcast, and usually the two cannot be used. How to explain it? Thank you
05-09-2017 10:06 PM
yeah those are the basic of IP addresses , all 0's in their subnet (based on mask) are network addresses and all 1's are broadcasts. you just cant use them.
05-10-2017 08:31 PM
Thank you for your reply. so if we have 10.1.1.0/30 in point to point link, do you think 10.1.1.0/30 and 10.1.1.3/30 useful?
05-10-2017 11:43 PM
No, not on a point to point link, because there is no point to do a broadcast on a link with only 2 endpoints.
please rate if useful
05-09-2017 10:41 PM
/31 bit subnets don't have a network and broadcast address, and are typically used on point to point links where both network and broadcast addresses are not needed.
So, 10.1.1.0/31 and 10.1.1.1/31 are actually usable addresses. ISPs use /31 bit masks a lot to conserve IP addresses...
05-09-2017 11:31 PM
In addition to what Georg explained, you can read more about it in RFC 3021 where this is defined.
05-10-2017 05:02 AM
As host routes, but generally routing protocols that support /31s just carry the /31.
Oh, we also use /31s in our network for p-2-p use, and have lots of them - again with a routing protocol that supports, they work just fine.
