explain output for "show license all"
whistleblower14
Hi all,
I've been racking my brain for hours because I don't understand why the output "show license all" on 2 identical router models with the same software delivers a different output...
- why are in the second output more features listed?
- why is in the first one, no IPBaseK9 seen altough both routers are using this set?
- why is in the second output the Index 3 the License State: Active BUT Not in Use?
Index 3 Feature: ipbasek9
Period left: Life time
License Type: Permanent
License State: Active, Not in Use
License Store: Primary License Storage
License Store: Built-In License Storage
StoreIndex: 0 Feature: appxk9 Version: 1.0
License Type: EvalRightToUse
License State: Active, Not in Use, EULA not accepted
Evaluation total period: 8 weeks 4 days
Evaluation period left: 8 weeks 4 days
Period used: 0 minute 0 second
License Count: Non-Counted
License Priority: None
StoreIndex: 1 Feature: securityk9 Version: 1.0
StoreIndex: 2 Feature: FoundationSuiteK9 Version: 1.0
StoreIndex: 3 Feature: throughput Version: 1.0
Index 1 Feature: appxk9
Period left: Not Activated
Period Used: 0 minute 0 second
Index 2 Feature: securityk9
License Priority: Medium
Index 4 Feature: FoundationSuiteK9
Index 5 Feature: hseck9
Index 6 Feature: throughput
Index 7 Feature: internal_service
5 Replies 5
whistleblower14
Hi all,
balaji.bandi
waht device is this, what IOS Code ?
you need accept EULA :
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/csa/command/csa-cr-book/csa-l1.html
This explains better :
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/csa/command/csa-cr-book/csa-s1.html
BB
the Router Device-Type = C1111-8P running Version 16.9.7
@balaji.bandi after excepting the EULA and a reboot of the router the license-state on one of the routers is now Active and in use! what could have happened when I did’nt agreed the EULA?
what I still don‘t understand is why on the other router the license ipbasek9 don’t show up?
You need to accept EULA for the activate since that is the License Agreement right?
BB
