Export Configuration File to Cisco.
Hello, I wonder if I can export a configuration file saved in txt to the speck. Thanks in advance
Latchum Naidu
Hope this link will help you...
http://www.rpm.org/max-rpm/s1-rpm-build-creating-spec-file.html
If this answered your question please click on correct answer.
Nadiu.
