ā03-18-2011 02:32 PM - edited ā03-04-2019 11:48 AM
Hello
I've got 871 router
The was c870-advsecurityk9-mz.123-8.YI2.bin inside. After I upgraded IOS to c870-advsecurityk9-mz.124-9.T7.bin and reload, 871 dorp to ROMMON with strange error
__________________________________________________________________________
Receiving c870-advsecurityk9-mz.124-9.T7.bin from 192.168.0.1 !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
File reception completed.
Launching
Self decompressing the image : ########################################################################################## [OK]
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software, C870 Software (C870-ADVSECURITYK9-M), Version 12.4(9)T7, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Thu 10-Jan-08 20:55 by prod_rel_team
Image text-base: 0x8002008C, data-base: 0x817D8298
Queued messages:
*Mar 1 00:00:10.227: %SYS-3-LOGGER_FLUSHING: System pausing to ensure console debugging output.
*Mar 1 00:00:10.207: %SMC-2-BAD_ID_HW: Failed Identification Test in 0/-1/-1 [1/0]
The module in 0/-1/-1 in this router may not be a genuine
Cisco product. Cisco warranties and support programs only
apply to genuine Cisco products. If Cisco determines that
your insertion of non-Cisco memory, WIC cards, AIM cards,
Network Modules, SPA cards, GBICs or other modules into a
Cisco product is the cause of a support issue, Cisco may
deny support under your warranty or under a Cisco support
program such as SmartNet.
System Bootstrap, Version 12.3(8r)YI4, RELEASE SOFTWARE
Copyright (c) 2006 by cisco Systems, Inc.
C870 series (Board ID: 3-148) platform with 131072 Kbytes of main memory
rommon 1 >
I was trying to
1) format flash: (many times
2) upload different 12.4T IOS'es
noting help, every time after reload 871 drops to rommon
I did some googling but nothing interesting was found.
may be it's related to cookie problem but thera no instruction how to fix it
The only way to upload back c870-advsecurityk9-mz.123-8.YI2.bin.
871 starts normally when c870-advsecurityk9-mz.123-8.YI2.bin. inside but it's VERY old IOS and not stable enough.
/lexxa
ā03-18-2011 02:55 PM
As the message suggests this could be due a bad HW or non Cisco HW in the router. Please raise a TAC case as this
could be due to hw problem or a bug.
Regards.
ā03-20-2011 05:25 PM
The hardware may be defective or not genuine Cisco hardware. Newer software checks for the presence of appopriate Cisco manufacturing information programmed into the router in order to prevent non-Cisco hardware from runnng IOS. Unfortunately, if the parts are damaged or corrupted in genuine hardware, you will get the same message.
If this is genuine Cisco hardware, you should contact Cisco or your the place where you purchased the unit for replacement or repair.
