GET VPN Router Key Server
Is it possible to have a Router acting as Group Member and Key Server at same time?
What are the requirements for the Key Server?
johnlloyd_13
Level 9
Level 9
hi,
yes, you can configure the router to be either the key server or group member. it depends on the group/identity number configured.
see the below requirements to configure a key server (and sample config). please remember to rate useful post. thanks!
Perform the following sequence to configure a GET VPN key server:
Task 1: (Optional) Configure an IKE policy. The default IKE policy can be used.
Task 2: Generate/configure authentication credentials for all group members.
Task 3: Generate or choose existing RSA keys on the key server to authenticate rekeys.
Task 4: Configure a traffic protection policy.
Task 5: Enable and configure the GET VPN key server function itself.
Task 6: (Optional) Tune the rekeying policy.
KS#configure terminal
KS(config)#crypto isakmp policy 10
KS(config-isakmp)#encryption aes 128
KS(config-isakmp)#hash sha
KS(config-isakmp)#group 5
KS(config-isakmp)#authentication pre-share
KS(config-isakmp)#exit
KS(config)#crypto isakmp key 0 c1sc0k3y address 0.0.0.0
KS(config)#ip domain name lab.com
KS(config)#crypto key generate rsa modulus 2048 label GETVPN_KEY
KS(config)#crypto ipsec transform-set TSET esp-aes esp-sha-hmac
KS(cfg-crypto-trans)#mode transport
KS(cfg-crypto-trans)#exit
KS(config)#crypto ipsec profile GETVPN_PROFILE
KS(ipsec-profile)#set transform-set TSET
KS(ipsec-profile)#exit
KS(config)#ip access-list extended GETVPN_ACL
KS(config-ext-nacl)#permit ip any any
KS(config-ext-nacl)#exit
KS(config)#crypto gdoi group GETVPN_GROUP
KS(config-gdoi-group)#identity number 1234
KS(config-gdoi-group)#server local
KS(gdoi-local-server)#address ipv4 192.168.1.1
KS(gdoi-local-server)#rekey authentication mypubkey rsa GETVPN_KEY
KS(gdoi-local-server)#rekey transport unicast
KS(gdoi-local-server)#sa ipsec 10
KS(gdoi-sa-ipsec)#profile GETVPN_PROFILE
KS(gdoi-sa-ipsec)#match address ipv4 GETVPN_ACL
KS(gdoi-sa-ipsec)#end
KS#show crypto gdoi
GROUP INFORMATION
    Group Name               : GETVPN_GROUP (Unicast)
    Group Identity           : 1234
    Group Members            : 0
    IPSec SA Direction       : Both
    Active Group Server      : Local
    Group Rekey Lifetime     : 86400 secs
    Rekey Retransmit Period  : 10 secs
    Rekey Retransmit Attempts: 2
      IPSec SA Number        : 10
      IPSec SA Rekey Lifetime: 3600 secs
      Profile Name           : GETVPN_PROFILE
      Replay method          : Count Based
      Replay Window Size     : 64
      ACL Configured         : access-list GETVPN_ACL
    Group Server list        : Local
