Extend Vlan over MPLS
saquib.tandel
Is it possible to extend vlan over an MPLS Cloud.
What are the benefits fon running GRE tunnels over MPLS Cloud
thanks
ST
DuncanM2008
I think a little more information is required but in essence, yes.
You can extend a Layer 2 VLAN as well as other Layer 2 technologies over MPLS, to do Vlan's you normally use EoMPLS (Etherner over MPLS) otherwise known as pseudo-wire services.
These can either be point-point or point-multipoint (L2VFI).
http://www.cisco.com/en/US/docs/switches/metro/catalyst3750m/software/release/12.2_25_seg_seg1/configuration/guide/swmpls.pdf
It all depends on how far your "MPLS Cloud" extends and the sort of hardware platforms your using as well as an idea of what your trying to achieve.
Basically, a little more detail / background is required to elborate any further.
HTH.
