05-12-2006 12:43 AM - edited 03-03-2019 12:40 PM
Hi all,
we are trying to connect to an Ericsson ATM switch. The provider gave us VCIs in the range 1001 and up to 1259. Cisco by default goes between range (0-1023)
We are using a Cisco 3662 with ATM STM-1 SMI OC3 (NM-1A-OC3SMI=).
Regards.
05-12-2006 12:47 AM
You should be able to use the following command to change that:
atm vc-per-vp
Pls do remember to rate posts that help.
Paresh
05-21-2006 03:14 AM
Hi Paresh,
Unfortunately not much luck...
According to Cisco, the specific card we have, cannot go beyond value 1023.
http://www.cisco.com/en/US/customer/tech/tk39/tk48/technologies_tech_note09186a00801086c5.shtml
Thanks for your help though.
