External NAT works fine, but adresses are not reached from LAN
rpmsnepvangers
We are using a Cisco 1841 router for internet access. We created NAT for our webservers (http and https). Our websites can be reached from the WAN. Now we can not access our https website from the LAN (using the WAN IP adress).
Config:
interface FastEthernet0/0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
duplex auto
speed auto
no mop enabled
interface FastEthernet0/0.1
description DataVLAN
encapsulation dot1Q 1 native
ip address 10.0.0.3 255.255.255.0
no ip redirects
ip nat inside
no snmp trap link-status
no cdp enable
interface FastEthernet0/0.10
description VoiceVLAN
encapsulation dot1Q 10
ip address 10.0.10.3 255.255.255.0
no ip redirects
ip nat inside
no cdp enable
interface FastEthernet0/1
description WAN
bandwidth 10000
ip address A.B.C.D 255.255.255.192
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
ip route-cache flow
duplex auto
speed auto
no mop enabled
service-policy output SDM-QoS-Policy-1
ip classless
ip route 0.0.0.0 0.0.0.0 A.B.C.D. permanent
ip http server
ip http authentication local
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat translation timeout 200
no ip nat service skinny tcp port 2000
no ip nat service sip udp port 5060
ip nat inside source list 1 interface FastEthernet0/1 overload
ip nat inside source list 2 interface FastEthernet0/1 overload
ip nat inside source static tcp 10.0.0.24 4673 interface FastEthernet0/1 4673
ip nat inside source static tcp 10.0.0.24 4663 interface FastEthernet0/1 4663
ip nat inside source static udp 10.0.0.24 4674 interface FastEthernet0/1 4674
ip nat inside source static tcp 10.0.0.6 80 interface FastEthernet0/1 8080
ip nat inside source static tcp 10.0.0.24 3389 interface FastEthernet0/1 50697
ip nat inside source static tcp 10.0.0.1 3389 interface FastEthernet0/1 3390
ip nat inside source static tcp 10.0.0.75 3389 interface FastEthernet0/1 26681
ip nat inside source static tcp 10.0.0.96 3389 interface FastEthernet0/1 48419
ip nat inside source static tcp 10.0.0.6 3389 interface FastEthernet0/1 3389
ip nat inside source static tcp 10.0.0.2 3389 interface FastEthernet0/1 7676
ip nat inside source static tcp 10.0.0.5 25 interface FastEthernet0/1 25
ip nat inside source static tcp 10.0.0.5 4822 interface FastEthernet0/1 4822
ip nat inside source static tcp 10.0.0.1 3690 interface FastEthernet0/1 3690
ip nat inside source static tcp 10.0.0.5 443 interface FastEthernet0/1 443
ip nat inside source static tcp 10.0.0.13 80 interface FastEthernet0/1 80
ip nat inside source static tcp 10.0.0.6 21 interface FastEthernet0/1 21
Can somebody give my a hand??
Greetz Richard
9 Replies 9
Giuseppe Larosa
Hello Richard,
I'm not sure I've understood your issue.
I see that you have configured several nat static statements for your internal servers and you say they work: that from internet you can access these services.
Then you say that you cannot access from the lan (the nat inside I guess) the https server by using the wan ip address.
Nat works by classifying interfaces in inside and outside with a precise meaning: only traffic that crosses a pair of interfaces one inside and one outside is translated.
So when you try to access your https from inside you have to use the real internal (inside local) ip address to access it not the address that will be used when accessing from the outer world.
Hope to help
Giuseppe
Hello Giuseppe, you have understood my issue correctly.
The problem is that some applications are always using the same (internet) address. When we are working inside (lan) or outside (wan). Is there some way to resolve this problem??
thank you in advance
Richard
Hello Richard,
this is more a DNS issue I suppose.
A possible fix could be that of using the hosts file in the devices to provide the local inside entry.
(if linux based otherwise the file should be the lmhosts in a windows machine)
Thanks for your kind remarks
Hope to help
Giuseppe
Hello Guiseppe,
I know this normaly is a dns issue. But before we used an other internet router. With this router everything worked fine. So i thought to solve it in the router and not DNS. I don't know everything about DNS. I don't know if DNS can 'route' on specific ports. I have 5 or 6 servers that work on several ports.
thank you for your help
Richard
Mayby I can use a virtual nat interface?
Is it working with http?
from wan: http://sap.abcd.nl connects to the webserver.
from lan: http://sap.abcd.nl connects to the 1841 router.
This address is not configured in DNS. Before we used the 1841 router, all traffic from the lan to http://sap.abcd.nl connected to the webserver trough WAN.
have you tried to reach the server by typing the ip address ? (http://@ip)
LB
same result: not possible
steve_steele
I think that you can do it using split DNS.
http://www.cisco.com/en/US/docs/ios/12_4t/12_4t11/htspldns.html#wp1405225
Configure all internal clients to use the router as the dns server.
Configure the router to forward dns queries to your current dns server.
Configure the router with a static dns entry pointing to the local internal ip address of the web server.
Steve
