External SSH
dan_miles86
I hope someone can save my sanity.
I'm trying to setup external SSH access to my router. Internal is working fine. I thought prehaps SSH port was blocked by ISP so tried a different port but have the same lack off success.
Full config included below with external IP's and Passwords replaced with ##################.
version 12.4
hostname ##################
boot-start-marker
boot-end-marker
logging message-counter syslog
enable secret 5 ##################
enable password ##################
aaa new-model
aaa authentication login TERMINAL-LINES local
aaa session-id common
dot11 syslog
ip source-route
ip cef
ip dhcp excluded-address 192.168.30.1 192.168.30.100
ip dhcp excluded-address 192.168.31.1 192.168.31.100
ip dhcp excluded-address 192.168.32.1 192.168.32.100
ip dhcp pool DynamicPool
   network 192.168.30.0 255.255.255.0
   dns-server 192.168.30.1 8.8.8.8 208.67.222.222
   default-router 192.168.30.1
   lease 0 0 15
ip dhcp pool Tony-PC
   host 192.168.30.10 255.255.255.0
   client-identifier 0100.1e8c.6d85.3e
   lease infinite
ip dhcp pool VisitorPool
   network 192.168.31.0 255.255.255.0
   dns-server 8.8.8.8 8.8.4.4 208.67.222.222
   default-router 192.168.31.1
   lease 0 0 15
ip dhcp pool GuestPool
   network 192.168.32.0 255.255.255.0
   default-router 192.168.32.1
   lease 0 0 15
ip domain name ##################
ip host switch 192.168.30.5
ip host router 192.168.30.1
ip host unifi ##################
ip host tony-pc 192.168.30.10
ip name-server 8.8.8.8
ip name-server 8.8.4.4
ip name-server 208.67.222.222
ip name-server 208.67.220.220
no ipv6 cef
voice-card 0
username ################## password 0 ##################
archive
 log config
  hidekeys
ip ssh port 8083 rotary 1
ip ssh rsa keypair-name ##################
interface GigabitEthernet0/0
 ip address ################## 255.255.255.248
 ip nat outside
 ip virtual-reassembly
 duplex auto
 speed auto
interface GigabitEthernet0/1
 no ip address
 shutdown
 duplex auto
 speed auto
 no mop enabled
interface GigabitEthernet1/0
 ip address 192.168.30.1 255.255.255.0
 ip access-group native in
 ip nat inside
interface GigabitEthernet1/0.1
 encapsulation dot1Q 40
 ip address 192.168.31.1 255.255.255.0
 ip access-group visitor in
 ip nat inside
interface GigabitEthernet1/0.2
 encapsulation dot1Q 50
 ip address 192.168.32.1 255.255.255.0
 ip access-group guest in
 ip nat inside
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0 ##################
no ip http server
no ip http secure-server
ip dns server
ip nat inside source list 100 interface GigabitEthernet0/0 overload
ip nat inside source static tcp 192.168.30.10 3389 interface GigabitEthernet0/0 3389
ip nat inside source static udp 192.168.30.10 3389 interface GigabitEthernet0/0 3389
ip access-list extended guest
 deny   ip 192.168.32.0 0.0.0.255 192.168.30.0 0.0.0.255
 deny   ip 192.168.32.0 0.0.0.255 192.168.31.0 0.0.0.255
 permit ip any any
ip access-list extended management
 permit ip 192.168.30.0 0.0.0.255 any
 permit ip 192.168.20.0 0.0.0.255 any
 permit ip ################## 0.0.0.255 any
ip access-list extended native
 deny   ip 192.168.30.0 0.0.0.255 192.168.31.0 0.0.0.255
 deny   ip 192.168.30.0 0.0.0.255 192.168.32.0 0.0.0.255
 permit ip any any
ip access-list extended visitor
 deny   ip 192.168.31.0 0.0.0.255 192.168.30.0 0.0.0.255
 deny   ip 192.168.31.0 0.0.0.255 192.168.32.0 0.0.0.255
 permit ip any any
access-list 100 permit ip any any
dialer-list 1 protocol ip permit
control-plane
ccm-manager fax protocol cisco
mgcp fax t38 ecm
line con 0
line aux 0
line 66
 no activation-character
 no exec
 transport preferred none
 transport input all
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
line vty 0 4
 access-class management in
 login authentication TERMINAL-LINES
 transport input all
line vty 5 10
 password Line ##################
 rotary 1
 transport input all
scheduler allocate 20000 1000
end
Your ACL 100 used with NAT can cause these problems. Try the following ACL:
access-list 100 deny ip any 192.168.0.0 0.0.255.255
access-list 100 permit ip 192.168.0.0 0.0.255.255 any
Spot on and so simple. Thank you Karsten!
