10-08-2019 10:40 AM
Hello has any encountered the following error message before and if so how did you resolve it?
I am using a Cisco 1841 Router, running the following code: c1841-advipservicesk9-mz.124-24.T2.bin.
The error message is:
Thank you in advance for your assistance!
10-08-2019 10:52 AM - edited 10-08-2019 10:58 AM
Can you post the configuration and output of show crypto ipsec client ezvpn
Also post the complete logs
10-30-2019 07:09 AM
Apologies for the late reply!
Here is the output you request...
Easy VPN Remote Phase: 8
Tunnel name : SS_Solution
Inside interface list: Vlan1, Loopback0
Outside interface: FastEthernet0/0
Current State: NO_CHANGE
Last Event: RESET
Save Password: Disallowed
Current EzVPN Peer: 204.27.156.206
10-30-2019 07:29 AM
post the full running configuration of your 1841 router...
10-30-2019 07:44 AM
The router is 1841
Current Flash: c1841-advipservicesk9-mz.124-24.T2.bin
Log Buffer:
Log Buffer (16384 bytes):
ct 30 14:43:22 gmt: EZVPN(SS_Solution): Resetting the EZVPN state machine to recover
12342229: Oct 30 14:43:23 gmt: EZVPN(SS_Solution): *** Logic Error ***
12342230: Oct 30 14:43:23 gmt: EZVPN(SS_Solution): Current State: NO_CHANGE
12342231: Oct 30 14:43:23 gmt: EZVPN(SS_Solution): Event: RESET
12342232: Oct 30 14:43:23 gmt: EZVPN(SS_Solution): Resetting the EZVPN state machine to recover
12342233: Oct 30 14:43:24 gmt: EZVPN(SS_Solution): *** Logic Error ***
12342234: Oct 30 14:43:24 gmt: EZVPN(SS_Solution): Current State: NO_CHANGE
12342235: Oct 30 14:43:24 gmt: EZVPN(SS_Solution): Event: RESET
12342236: Oct 30 14:43:24 gmt: EZVPN(SS_Solution): Resetting the EZVPN state machine to recover
12342237: Oct 30 14:43:25 gmt: EZVPN(SS_Solution): *** Logic Error ***
12342238: Oct 30 14:43:25 gmt: EZVPN(SS_Solution): Current State: NO_CHANGE
12342239: Oct 30 14:43:25 gmt: EZVPN(SS_Solution): Event: RESET
12342240: Oct 30 14:43:25 gmt: EZVPN(SS_Solution): Resetting the EZVPN state machine to recover
12342241: Oct 30 14:43:26 gmt: EZVPN(SS_Solution): *** Logic Error ***
12342242: Oct 30 14:43:26 gmt: EZVPN(SS_Solution): Current State: NO_CHANGE
12342243: Oct 30 14:43:26 gmt: EZVPN(SS_Solution): Event: RESET
12342244: Oct 30 14:43:26 gmt: EZVPN(SS_Solution): Resetting the EZVPN state machine to recover
12342245: Oct 30 14:43:27 gmt: EZVPN(SS_Solution): *** Logic Error ***
12342246: Oct 30 14:43:27 gmt: EZVPN(SS_Solution): Current State: NO_CHANGE
12342247: Oct 30 14:43:27 gmt: EZVPN(SS_Solution): Event: RESET
12342248: Oct 30 14:43:27 gmt: EZVPN(SS_Solution): Resetting the EZVPN state machine to recover
12342249: Oct 30 14:43:28 gmt: EZVPN(SS_Solution): *** Logic Error ***
12342250: Oct 30 14:43:28 gmt: EZVPN(SS_Solution): Current State: NO_CHANGE
12342251: Oct 30 14:43:28 gmt: EZVPN(SS_Solution): Event: RESET
12342252: Oct 30 14:43:28 gmt: EZVPN(SS_Solution): Resetting the EZVPN state machine to recover
12342253: Oct 30 14:43:29 gmt: %SEC-6-IPACCESSLOGP: list acl_outside denied tcp 45.136.110.48(48346) -> 142.59.80.5(9613), 1 packet
12342254: Oct 30 14:43:29 gmt: %SYS-3-MGDTIMER: Parent is a leaf, timer first expired, timer = 66668184. -Process= "EzVPN Client Process", ipl= 0, pid= 254, -Traceback= 0x62202258z 0x62C1F394z 0x621F7314z 0x621F72F8z
12342255: Oct 30 14:43:29 gmt: EZVPN(SS_Solution): *** Logic Error ***
12342256: Oct 30 14:43:29 gmt: EZVPN(SS_Solution): Current State: NO_CHANGE
12342257: Oct 30 14:43:29 gmt: EZVPN(SS_Solution): Event: RESET
12342258: Oct 30 14:43:30 gmt: EZVPN(SS_Solution): *** Logic Error ***
12342259: Oct 30 14:43:30 gmt: EZVPN(SS_Solution): Current State: NO_CHANGE
12342260: Oct 30 14:43:30 gmt: EZVPN(SS_Solution): Event: RESET
12342261: Oct 30 14:43:30 gmt: EZVPN(SS_Solution): Resetting the EZVPN state machine to recover
12342262: Oct 30 14:43:31 gmt: EZVPN(SS_Solution): *** Logic Error ***
12342263: Oct 30 14:43:31 gmt: EZVPN(SS_Solution): Current State: NO_CHANGE
12342264: Oct 30 14:43:31 gmt: EZVPN(SS_Solution): Event: RESET
12342265: Oct 30 14:43:31 gmt: EZVPN(SS_Solution): Resetting the EZVPN state machine to recover
12342266: Oct 30 14:43:32 gmt: EZVPN(SS_Solution): *** Logic Error ***
12342267: Oct 30 14:43:32 gmt: EZVPN(SS_Solution): Current State: NO_CHANGE
12342268: Oct 30 14:43:32 gmt: EZVPN(SS_Solution): Event: RESET
12342269: Oct 30 14:43:32 gmt: EZVPN(SS_Solution): Resetting the EZVPN state machine to recover
12342270: Oct 30 14:43:33 gmt: EZVPN(SS_Solution): *** Logic Error ***
12342271: Oct 30 14:43:33 gmt: EZVPN(SS_Solution): Current State: NO_CHANGE
12342272: Oct 30 14:43:33 gmt: EZVPN(SS_Solution): Event: RESET
12342273: Oct 30 14:43:33 gmt: EZVPN(SS_Solution): Resetting the EZVPN state machine to recover
12342274: Oct 30 14:43:34 gmt: EZVPN(SS_Solution): *** Logic Error ***
12342275: Oct 30 14:43:34 gmt: EZVPN(SS_Solution): Current State: NO_CHANGE
12342276: Oct 30 14:43:34 gmt: EZVPN(SS_Solution): Event: RESET
12342277: Oct 30 14:43:34 gmt: EZVPN(SS_Solution): Resetting the EZVPN state machine to recover
12342278: Oct 30 14:43:35 gmt: EZVPN(SS_Solution): *** Logic Error ***
12342279: Oct 30 14:43:35 gmt: EZVPN(SS_Solution): Current State: NO_CHANGE
12342280: Oct 30 14:43:35 gmt: EZVPN(SS_Solution): Event: RESET
12342281: Oct 30 14:43:35 gmt: EZVPN(SS_Solution): Resetting the EZVPN state machine to recover
12342282: Oct 30 14:43:36 gmt: EZVPN(SS_Solution): *** Logic Error ***
12342283: Oct 30 14:43:36 gmt: EZVPN(SS_Solution): Current State: NO_CHANGE
12342284: Oct 30 14:43:36 gmt: EZVPN(SS_Solution): Event: RESET
12342285: Oct 30 14:43:36 gmt: EZVPN(SS_Solution): Resetting the EZVPN state machine to recover
12342286: Oct 30 14:43:37 gmt: EZVPN(SS_Solution): *** Logic Error ***
12342287: Oct 30 14:43:37 gmt: EZVPN(SS_Solution): Current State: NO_CHANGE
12342288: Oct 30 14:43:37 gmt: EZVPN(SS_Solution): Event: RESET
12342289: Oct 30 14:43:37 gmt: EZVPN(SS_Solution): Resetting the EZVPN state machine to recover
12342290: Oct 30 14:43:38 gmt: EZVPN(SS_Solution): *** Logic Error ***
12342291: Oct 30 14:43:38 gmt: EZVPN(SS_Solution): Current State: NO_CHANGE
12342292: Oct 30 14:43:38 gmt: EZVPN(SS_Solution): Event: RESET
12342293: Oct 30 14:43:38 gmt: EZVPN(SS_Solution): Resetting the EZVPN state machine to recover
12342294: Oct 30 14:43:39 gmt: %SYS-3-MGDTIMER: Parent is a leaf, timer first expired, timer = 66668184. -Process= "EzVPN Client Process", ipl= 0, pid= 254, -Traceback= 0x62202258z 0x62C1F394z 0x621F7314z 0x621F72F8z
12342295: Oct 30 14:43:39 gmt: EZVPN(SS_Solution): *** Logic Error ***
12342296: Oct 30 14:43:39 gmt: EZVPN(SS_Solution): Current State: NO_CHANGE
12342297: Oct 30 14:43:39 gmt: EZVPN(SS_Solution): Event: RESET
12342298: Oct 30 14:43:39 gmt: EZVPN(SS_Solution): Resetting the EZVPN state machine to recover
12342299: Oct 30 14:43:40 gmt: %SEC-6-IPACCESSLOGP: list acl_outside denied tcp 185.176.27.26(54710) -> 142.59.80.5(3400), 1 packet
12342300: Oct 30 14:43:40 gmt: EZVPN(SS_Solution): *** Logic Error ***
12342301: Oct 30 14:43:40 gmt: EZVPN(SS_Solution): Current State: NO_CHANGE
12342302: Oct 30 14:43:40 gmt: EZVPN(SS_Solution): Event: RESET
12342303: Oct 30 14:43:41 gmt: EZVPN(SS_Solution): *** Logic Error ***
12342304: Oct 30 14:43:41 gmt: EZVPN(SS_Solution): Current State: NO_CHANGE
12342305: Oct 30 14:43:41 gmt: EZVPN(SS_Solution): Event: RESET
12342306: Oct 30 14:43:41 gmt: EZVPN(SS_Solution): Resetting the EZVPN state machine to recover
12342307: Oct 30 14:43:42 gmt: EZVPN(SS_Solution): *** Logic Error ***
12342308: Oct 30 14:43:42 gmt: EZVPN(SS_Solution): Current State: NO_CHANGE
12342309: Oct 30 14:43:42 gmt: EZVPN(SS_Solution): Event: RESET
12342310: Oct 30 14:43:42 gmt: EZVPN(SS_Solution): Resetting the EZVPN state machine to recover
12342311: Oct 30 14:43:43 gmt: EZVPN(SS_Solution): *** Logic Error ***
12342312: Oct 30 14:43:43 gmt: EZVPN(SS_Solution): Current State: NO_CHANGE
12342313: Oct 30 14:43:43 gmt: EZVPN(SS_Solution): Event: RESET
12342314: Oct 30 14:43:43 gmt: EZVPN(SS_Solution): Resetting the EZVPN state machine to recover
12342315: Oct 30 14:43:44 gmt: EZVPN(SS_Solution): *** Logic Error ***
12342316: Oct 30 14:43:44 gmt: EZVPN(SS_Solution): Current State: NO_CHANGE
12342317: Oct 30 14:43:44 gmt: EZVPN(SS_Solution): Event: RESET
12342318: Oct 30 14:43:44 gmt: EZVPN(SS_Solution): Resetting the EZVPN state machine to recover
12342319: Oct 30 14:43:45 gmt: EZVPN(SS_Solution): *** Logic Error ***
12342320: Oct 30 14:43:45 gmt: EZVPN(SS_Solution): Current State: NO_CHANGE
12342321: Oct 30 14:43:45 gmt: EZVPN(SS_Solution): Event: RESET
12342322: Oct 30 14:43:45 gmt: EZVPN(SS_Solution): Resetting the EZVPN state machine to recover
12342323: Oct 30 14:43:46 gmt: EZVPN(SS_Solution): *** Logic Error ***
12342324: Oct 30 14:43:46 gmt: EZVPN(SS_Solution): Current State: NO_CHANGE
12342325: Oct 30 14:43:46 gmt: EZVPN(SS_Solution): Event: SOCKET_ERROR
12342326: Oct 30 14:43:46 gmt: EZVPN(SS_Solution): Resetting the EZVPN state machine to recover
12342327: Oct 30 14:43:47 gmt: EZVPN(SS_Solution): *** Logic Error ***
12342328: Oct 30 14:43:47 gmt: EZVPN(SS_Solution): Current State: NO_CHANGE
12342329: Oct 30 14:43:47 gmt: EZVPN(SS_Solution): Event: RESET
12342330: Oct 30 14:43:47 gmt: EZVPN(SS_Solution): Resetting the EZVPN state machine to recover
12342331: Oct 30 14:43:48 gmt: EZVPN(SS_Solution): *** Logic Error ***
12342332: Oct 30 14:43:48 gmt: EZVPN(SS_Solution): Current State: NO_CHANGE
12342333: Oct 30 14:43:48 gmt: EZVPN(SS_Solution): Event: SOCKET_ERROR
12342334: Oct 30 14:43:48 gmt: EZVPN(SS_Solution): Resetting the EZVPN state machine to recover
12342335: Oct 30 14:43:49 gmt: %SYS-3-MGDTIMER: Parent is a leaf, timer first expired, timer = 66668184. -Process= "EzVPN Client Process", ipl= 0, pid= 254, -Traceback= 0x62202258z 0x62C1F394z 0x621F7314z 0x621F72F8z
12342336: Oct 30 14:43:49 gmt: EZVPN(SS_Solution): *** Logic Error ***
12342337: Oct 30 14:43:49 gmt: EZVPN(SS_Solution): Current State: NO_CHANGE
12342338: Oct 30 14:43:49 gmt: EZVPN(SS_Solution): Event: SOCKET_ERROR
12342339: Oct 30 14:43:49 gmt: EZVPN(SS_Solution): Resetting the EZVPN state machine to recover
12342340: Oct 30 14:43:50 gmt: EZVPN(SS_Solution): *** Logic Error ***
12342341: Oct 30 14:43:50 gmt: EZVPN(SS_Solution): Current State: NO_CHANGE
12342342: Oct 30 14:43:50 gmt: EZVPN(SS_Solution): Event: RESET
12342343: Oct 30 14:43:50 gmt: EZVPN(SS_Solution): Resetting the EZVPN state machine to recover
12342344: Oct 30 14:43:51 gmt: EZVPN(SS_Solution): *** Logic Error ***
12342345: Oct 30 14:43:51 gmt: EZVPN(SS_Solution): Current State: NO_CHANGE
12342346: Oct 30 14:43:51 gmt: EZVPN(SS_Solution): Event: RESET
12342347: Oct 30 14:43:51 gmt: EZVPN(SS_Solution): Resetting the EZVPN state machine to recover
12342348: Oct 30 14:43:52 gmt: EZVPN(SS_Solution): *** Logic Error ***
12342349: Oct 30 14:43:52 gmt: EZVPN(SS_Solution): Current State: NO_CHANGE
12342350: Oct 30 14:43:52 gmt: EZVPN(SS_Solution): Event: SOCKET_ERROR
12342351: Oct 30 14:43:52 gmt: EZVPN(SS_Solution): Resetting the EZVPN state machine to recover
12342352: Oct 30 14:43:53 gmt: EZVPN(SS_Solution): *** Logic Error ***
12342353: Oct 30 14:43:53 gmt: EZVPN(SS_Solution): Current State: NO_CHANGE
12342354: Oct 30 14:43:53 gmt: EZVPN(SS_Solution): Event: RESET
12342355: Oct 30 14:43:53 gmt: EZVPN(SS_Solution): Resetting the EZVPN state machine to recover
12342356: Oct 30 14:43:54 gmt: EZVPN(SS_Solution): *** Logic Error ***
12342357: Oct 30 14:43:54 gmt: EZVPN(SS_Solution): Current State: NO_CHANGE
12342358: Oct 30 14:43:54 gmt: EZVPN(SS_Solution): Event: SOCKET_ERROR
12342359: Oct 30 14:43:54 gmt: EZVPN(SS_Solution): Resetting the EZVPN state machine to recover
12342360: Oct 30 14:43:55 gmt: EZVPN(SS_Solution): *** Logic Error ***
12342361: Oct 30 14:43:55 gmt: EZVPN(SS_Solution): Current State: NO_CHANGE
12342362: Oct 30 14:43:55 gmt: EZVPN(SS_Solution): Event: RESET
12342363: Oct 30 14:43:55 gmt: EZVPN(SS_Solution): Resetting the EZVPN state machine to recover
12342364: Oct 30 14:43:56 gmt: EZVPN(SS_Solution): *** Logic Error ***
12342365: Oct 30 14:43:56 gmt: EZVPN(SS_Solution): Current State: NO_CHANGE
12342366: Oct 30 14:43:56 gmt: EZVPN(SS_Solution): Event: SOCKET_ERROR
12342367: Oct 30 14:43:56 gmt: EZVPN(SS_Solution): Resetting the EZVPN state machine to recover
12342368: Oct 30 14:43:57 gmt: EZVPN(SS_Solution): *** Logic Error ***
12342369: Oct 30 14:43:57 gmt: EZVPN(SS_Solution): Current State: NO_CHANGE
12342370: Oct 30 14:43:57 gmt: EZVPN(SS_Solution): Event: RESET
12342371: Oct 30 14:43:57 gmt: EZVPN(SS_Solution): Resetting the EZVPN state machine to recover
12342372: Oct 30 14:43:58 gmt: EZVPN(SS_Solution): *** Logic Error ***
12342373: Oct 30 14:43:58 gmt: EZVPN(SS_Solution): Current State: NO_CHANGE
12342374: Oct 30 14:43:58 gmt: EZVPN(SS_Solution): Event: RESET
12342375: Oct 30 14:43:58 gmt: EZVPN(SS_Solution): Resetting the EZVPN state machine to recover
12342376: Oct 30 14:43:59 gmt: %SYS-3-MGDTIMER: Parent is a leaf, timer first expired, timer = 66668184. -Process= "EzVPN Client Process", ipl= 0, pid= 254, -Traceback= 0x62202258z 0x62C1F394z 0x621F7314z 0x621F72F8z
12342377: Oct 30 14:43:59 gmt: EZVPN(SS_Solution): *** Logic Error ***
12342378: Oct 30 14:43:59 gmt: EZVPN(SS_Solution): Current State: NO_CHANGE
12342379: Oct 30 14:43:59 gmt: EZVPN(SS_Solution): Event: RESET
12342380: Oct 30 14:43:59 gmt: EZVPN(SS_Solution): Resetting the EZVPN state machine to recover
12342381: Oct 30 14:44:00 gmt: EZVPN(SS_Solution): *** Logic Error ***
12342382: Oct 30 14:44:00 gmt: EZVPN(SS_Solution): Current State: NO_CHANGE
12342383: Oct 30 14:44:00 gmt: EZVPN(SS_Solution): Event: RESET
12342384: Oct 30 14:44:00 gmt: EZVPN(SS_Solution): Resetting the EZVPN state machine to recover
12342385: Oct 30 14:44:01 gmt: EZVPN(SS_Solution): *** Logic Error ***
12342386: Oct 30 14:44:01 gmt: EZVPN(SS_Solution): Current State: NO_CHANGE
12342387: Oct 30 14:44:01 gmt: EZVPN(SS_Solution): Event: RESET
12342388: Oct 30 14:44:01 gmt: EZVPN(SS_Solution): Resetting the EZVPN state machine to recover
12342389: Oct 30 14:44:03 gmt: EZVPN(SS_Solution): *** Logic Error ***
12342390: Oct 30 14:44:03 gmt: EZVPN(SS_Solution): Current State: NO_CHANGE
12342391: Oct 30 14:44:03 gmt: EZVPN(SS_Solution): Event: RESET
12342392: Oct 30 14:44:03 gmt: EZVPN(SS_Solution): Resetting the EZVPN state machine to recover
12342393: Oct 30 14:44:04 gmt: EZVPN(SS_Solution): *** Logic Error ***
12342394: Oct 30 14:44:04 gmt: EZVPN(SS_Solution): Current State: NO_CHANGE
12342395: Oct 30 14:44:04 gmt: EZVPN(SS_Solution): Event: RESET
12342396: Oct 30 14:44:04 gmt: EZVPN(SS_Solution): Resetting the EZVPN state machine to recover
12342397: Oct 30 14:44:05 gmt: EZVPN(SS_Solution): *** Logic Error ***
12342398: Oct 30 14:44:05 gmt: EZVPN(SS_Solution): Current State: NO_CHANGE
12342399: Oct 30 14:44:05 gmt: EZVPN(SS_Solution): Event: RESET
12342400: Oct 30 14:44:05 gmt: EZVPN(SS_Solution): Resetting the EZVPN state machine to recover
12342401: Oct 30 14:44:06 gmt: EZVPN(SS_Solution): *** Logic Error ***
12342402: Oct 30 14:44:06 gmt: EZVPN(SS_Solution): Current State: NO_CHANGE
12342403: Oct 30 14:44:06 gmt: EZVPN(SS_Solution): Event: RESET
12342404: Oct 30 14:44:06 gmt: EZVPN(SS_Solution): Resetting the EZVPN state machine to recover
12342405: Oct 30 14:44:07 gmt: EZVPN(SS_Solution): *** Logic Error ***
12342406: Oct 30 14:44:07 gmt: EZVPN(SS_Solution): Current State: NO_CHANGE
12342407: Oct 30 14:44:07 gmt: EZVPN(SS_Solution): Event: RESET
12342408: Oct 30 14:44:07 gmt: EZVPN(SS_Solution): Resetting the EZVPN state machine to recover
12342409: Oct 30 14:44:08 gmt: EZVPN(SS_Solution): *** Logic Error ***
12342410: Oct 30 14:44:08 gmt: EZVPN(SS_Solution): Current State: NO_CHANGE
12342411: Oct 30 14:44:08 gmt: EZVPN(SS_Solution): Event: RESET
12342412: Oct 30 14:44:08 gmt: EZVPN(SS_Solution): Resetting the EZVPN state machine to recover
12342413: Oct 30 14:44:09 gmt: EZVPN(SS_Solution): *** Logic Error ***
12342414: Oct 30 14:44:09 gmt: EZVPN(SS_Solution): Current State: NO_CHANGE
12342415: Oct 30 14:44:09 gmt: EZVPN(SS_Solution): Event: RESET
12342416: Oct 30 14:44:09 gmt: EZVPN(SS_Solution): Resetting the EZVPN state machine to recover
12342417: Oct 30 14:44:10 gmt: %SYS-3-MGDTIMER: Parent is a leaf, timer first expired, timer = 66668184. -Process= "EzVPN Client Process", ipl= 0, pid= 254, -Traceback= 0x62202258z 0x62C1F394z 0x621F7314z 0x621F72F8z
12342418: Oct 30 14:44:10 gmt: EZVPN(SS_Solution): *** Logic Error ***
12342419: Oct 30 14:44:10 gmt: EZVPN(SS_Solution): Current State: NO_CHANGE
12342420: Oct 30 14:44:10 gmt: EZVPN(SS_Solution): Event: RESET
12342421: Oct 30 14:44:10 gmt: EZVPN(SS_Solution): Resetting the EZVPN state machine to recover
12342422: Oct 30 14:44:11 gmt: EZVPN(SS_Solution): *** Logic Error ***
12342423: Oct 30 14:44:11 gmt: EZVPN(SS_Solution): Current State: NO_CHANGE
12342424: Oct 30 14:44:11 gmt: EZVPN(SS_Solution): Event: RESET
12342425: Oct 30 14:44:11 gmt: EZVPN(SS_Solution): Resetting the EZVPN state machine to recover
12342426: Oct 30 14:44:12 gmt: EZVPN(SS_Solution): *** Logic Error ***
12342427: Oct 30 14:44:12 gmt: EZVPN(SS_Solution): Current State: NO_CHANGE
12342428: Oct 30 14:44:12 gmt: EZVPN(SS_Solution): Event: RESET
12342429: Oct 30 14:44:12 gmt: EZVPN(SS_Solution): Resetting the EZVPN state machine to recover
10-30-2019 10:05 AM
post the output of:
show run
