factor default to cisco switch/ROUTER by a button
netanellevi2
hello,
how I can to reset the config.text to a router or switch with mode button or reset button,
there is a specific platform of switch/router that can do it.
I need an ability that deletes the current configuration by an external button.
TNX :)
balaji.bandi
Depends on the device model you would like to reset.
normal how you can reset facotry as below steps : Cisco Standard.
https://dcloud-cms.cisco.com/help/reset-router.
https://www.cisco.com/c/en/us/support/docs/switches/catalyst-2900-xl-series-switches/24328-156.html
BB
