Route VLAN out of second Dialer IP
WonderfulIT
Hi all,
I've got an FTTC connection on Dialer 1 which works fine but that line has 3 public IP's with it, let's say 100.100.100.100, 100.100.100.101 and 100.100.100.102 and i've added the dialer with the IP of 100.100.100.100 and then 101 as a secondary IP.
I've got a VLAN 10 801Q on the LAN interface for another company within our building. The normal LAN is on 192.168.0.0 and this VLAN is on 10.10.10.0 and i want to router all traffic from 10.10.10.0 out of the dialer interface but using the seconday public ip of 100.100.100.101 ?
How do i do this ?
Hello
It seems possible if I am visualizing your network correctly however an you post a simple topology for validation and maybe the configuration of you rtr.
Kind Regards
Paul
you could create a NAT pool with the secondary IP address and link your Vllan 10 IP address space to that pool. This would look like below:
ip dhcp excluded-address 10.10.10.1
ip dhcp excluded-address 192.168.0.1
ip dhcp pool LAN
network 192.168.0.0 255.255.255.0
default-router 192.168.0.1
ip dhcp pool VLAN10
network 10.10.10.0 255.255.255.0
default-router 10.10.10.1
interface GigabitEthernet0/0
ip address 192.168.0.1 255.255.255.0
ip nat inside
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0/0.10
encapsulation dot1Q 10
ip address 10.10.10.1 255.255.255.0
ip nat inside
interface GigabitEthernet0/1
ip address 100.100.100.2 255.255.255.0 secondary
ip address 100.100.100.1 255.255.255.0
ip nat outside
ip nat pool PRIMARY 100.100.100.1 100.100.100.1 netmask 255.255.255.0
ip nat pool SECONDARY 100.100.100.2 100.100.100.2 netmask 255.255.255.0
ip nat inside source list 1 pool PRIMARY overload
ip nat inside source list 2 pool SECONDARY overload
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/1
access-list 1 permit 192.168.0.0 0.0.0.255
access-list 2 permit 10.10.10.0 0.0.0.255
