Factory defaulting 877 router disables CP and reverts to cli - help!
having messed up the config on the router due to an ISP giving incorrect information and changing their settings repeatedly, I decided to erase the startup config and reload the router. no problem, except now it tries to obtain a TFTP config file until that times out, then reverts to the CLI and CP won't connect any more, CP Express won't start from flash.
Help!
Yes, I know, I'm dumb... should have copied my original config first before erasing.
Gareth
cadet alain
Once in CLI: enter these ommands
1) create a local username-password pair ------> user cisco privilege 15 secret cisco where cisco is an example of username/password
2)enable http server ----> ip http server
3) authenticate http with the user/pass configured in 1)  ----> ip http authentication local
4)configure line vty for local login ----> line vty 0 4
        login local
5) configure an ip address on same subnet as your host with CCP installed --->
       interface f0/0
       ip address 192.168.1.254 255.255.255.0
       no shut
6) You can use CCP now
Regards.
Alain.
cadet alain
        login local
       interface f0/0
       no shut
Regards.
Alain.
