NAT/PAT port redirection
btillmanngc
I hope i ask this correclty.
I have one host IP address 192.168.3.50/24 that I need to connect to serveral inside hosts 10.10.10.1-8 via https and ssh.
ip nat inside source static tcp 10.10.10.1 443 192.168.3.50 443 extendable <-- This works fine. And any one to one works as well
ip nat inside source static tcp 10.10.10.3 443 192.168.3.50 22222 extendable <-- I can get the SSL certificate but receive RFC 5746, see CVE-2009-3555 error when the login page tries to pull up. But works fine certificates and all when in a one to one translateion.
I'm not sure if I need a route-map to translate 443 back out to source?
btillmanngc
here's an show ip nat translation... just not sure why the https or SSL connection would hang..
Pro Inside global      Inside local       Outside local      Outside global
tcp 192.168.3.50:443   10.10.10.1:443     ---                ---
tcp 192.168.3.50:65003 10.10.10.3:443     192.168.1.111:35562 192.168.1.111:35562
tcp 192.168.3.50:65003 10.10.10.3:443     192.168.1.111:35563 192.168.1.111:35563
tcp 192.168.3.50:65003 10.10.10.3:443     ---                ---
