Factory defaults terminal problem
slash281990
As I mentioned in previous post I made a factory default reset,
now I connect to my console,
with putty:
Serial type, speed 9600... Open
Now the black screen appears and I cant nothing write there... trying ctrl +c nothing helps..
please help
The problem is on CISCO 2800 ROUTER
16 Replies 16
Jon Marshall
slash281990 wrote:
would u like to enter initial  configuration dialog ? yes/ no
what should i select?
I just wanna boot the web interface and so on.. and after that to configure
Select yes and then assign your 10.x.x.x address to one of the ethernet interfaces.
Jon
thx
P.S and one more question... please say me how to set the default gateway on the router through wich the inet is comming? the command please
