failed license install
Hi all
Tried to install the license on the module, got this:
Switch#license install flash:<SN>_201303130550385930.lic
Installing licenses from "flash:<SN>_201303130550385930.lic"
% Error: Install failed. UDI SM-ES3G-16-P=:<SN> on license does not match any device
0/1 licenses were successfully installed
0/1 licenses were existing licenses
1/1 licenses were failed to install
Switch#sho license udi
Device#   PID                   SN              UDI
*0        SM-ES3G-16-P          <SN>     SM-ES3G-16-P:<SN>
Switch#  show license detail
Index: 1        Feature: ipservices                        Version: 1.0
        License Type: Evaluation
        License State: Active, Not in Use, EULA not accepted
            Evaluation total period: 8  weeks 4  days
            Evaluation period left: 8  weeks 4  days
        License Priority: None
        License Count: Non-Counted
        Store Index: 0
        Store Name: Evaluation License Storage
Switch#sh license feature
Feature name             Enforcement  Evaluation  Clear Allowed  Enabled
advipservices            yes          no          yes            no
ipservices               yes          yes         yes            no
ipbase                   no           no          yes            no
SN is correct
The only thing that I noticed is "=" sign on license PID,
Could this be causing the problem?
antonio.guirado
Level 3
Level 3
Check your license (it is a xml format file) and the serial number of your box. I thinks the problem
it is that you license has an different serial number.
Regards.
