QoS on ASR1001 router
amr_raouf
hi all,
     i need to know if the built-in GE ports in ASR1001 or ASR 1002 (-X) have the features of QoS without restrictions, or QoS features are supported in SPA modlue ports only?
thanks in advance for your support.
sean_evershed
Level 7
Level 7
Have a look at this guide. This will help you with your query:
http://www.cisco.com/en/US/docs/solutions/Enterprise/Video/qoswanaggasraag.html
Don't forget to rate all posts that are helpful
thanks for your reply Sean, but after reading the guide i didn't know the difference between ASR 1000 ports in QoS,
my query is about the difference between built-in ports and SPA ports when using QoS.
thanks for your help
