Failed SDM update
tobiaseichner
I tried updating SDM to the latest release, but failed doing so:
On the router's SDM Express interface I downloaded the update from cisco.com's website to my notebook (Win XP). Then started the installer.
After first failure, it advised me to follow some steps (active http/https server of the router, add user with level 15, configure ssh/telnet for level 15).
I did so and installation seems to work till the installer stated "Copy files to router". Then installation stopped with an error ("file transfer to router not possible" or similar).
Now when I call my router's WAN-IP, I don't get the SDM Express frontend anylonger, but some kind of "HTML terminal". Anyway, the router still seems to work fine.
So my questions are as following:
1. How can I get back SDM Express without destroying the router's configuration ?
2. When done, how do I properly update the SDM version ?
This is how my configuration looks like (show running-conf)
Building configuration...
Current configuration : 2321 bytes
version 12.3
service password-encryption
hostname adsl-gw
boot-start-marker
boot-end-marker
logging buffered 10000 debugging
enable secret 5 ####################
clock timezone PCTime 1
clock summer-time PCTime date Mar 30 2003 2:00 Oct 26 2003 3:00
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
no aaa new-model
ip subnet-zero
ip cef
ip ips po max-events 100
vpdn enable
vpdn-group 1
request-dialin
protocol pppoe
no ftp-server write-enable
isdn switch-type basic-net3
username ##### privilege 15 password 7 #######
no crypto isakmp ccm
interface BRI0
no ip address
shutdown
interface FastEthernet0
description zum DSL modem
no ip address
speed auto
half-duplex
pppoe enable
pppoe-client dial-pool-number 1
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
interface Vlan1
description LAN
ip address 194.77.100.89 255.255.255.248
interface Dialer1
description T-DSL dialer
ip address negotiated
ip access-group 102 in
ip mtu 1492
encapsulation ppp
ip tcp adjust-mss 1452
dialer pool 1
dialer-group 1
ppp chap refuse
ppp pap sent-username ###### password 7 #######
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
ip http server
ip http access-class 9
ip http authentication local
ip http secure-server
access-list 9 permit 194.77.100.88 0.0.0.7
access-list 101 permit ip any any
access-list 102 deny udp any 194.77.100.88 0.0.0.7 eq 3283
access-list 102 deny tcp any 194.77.100.88 0.0.0.7 eq 3283
access-list 102 deny udp any 194.77.100.88 0.0.0.7 eq 5900
access-list 102 deny tcp any 194.77.100.88 0.0.0.7 eq 5900
access-list 102 deny tcp any 194.77.100.88 0.0.0.7 eq 22
access-list 102 deny udp any 194.77.100.88 0.0.0.7 eq 22
access-list 102 deny udp any 194.77.100.88 0.0.0.7 eq 23
access-list 102 deny tcp any 194.77.100.88 0.0.0.7 eq telnet
access-list 102 permit ip any any
dialer-list 1 protocol ip list 101
control-plane
line con 0
password 7 ###########
login
line aux 0
line vty 0 4
privilege level 15
password 7 ############
login local
transport input telnet
end
(User names and passwords have been replaced with #####)
I really look forward your kind assistance :-)
tobiaseichner
Have I mistakenly used the wrong forum ? Please direct me to the correct one if this was the case...
Became answered in an other forum in the meanwhile. Thank you.
