Bookmark
Subscribe
796
Failing to configure PPoE for FFTC connection (UK Zen) on C887VA
veriton
I have a C887VA-M and am trying to configure it to connect to my ISP (Zen) using a BT Openreach modem, i.e. a via a PPPoE connection. Note I am not trying to set up VDSL directly (as I already have the ADSL RJ11 successfully configured for a different ISP).
This connection, via the BT Openreach modem, works fine on a C1841, to one of its FE ports, however I am finding that the C1841 is now too slow for my ~80Mb Zen connection. I can also connect directly using a PPPoE connection on my PC.
When comparting the two routers, the C1841 connects successfully like this:
146470: Apr 19 15:27:06.123:  Sending PADI: Interface = FastEthernet0/1
146471: Apr 19 15:27:06.175: PPPoE 0: I PADO  R:346e.9d92.8a2e L:0013.c341.7bf3 Fa0/1
146472: Apr 19 15:27:06.223: PPPoE 0: I PADO  R:346e.9d92.ad44 L:0013.c341.7bf3 Fa0/1
146473: Apr 19 15:27:06.223: PPPoE 0: I PADO  R:ac60.b65f.5215 L:0013.c341.7bf3 Fa0/1
146474: Apr 19 15:27:06.279: PPPoE 0: I PADO  R:346e.9d92.8b06 L:0013.c341.7bf3 Fa0/1
146475: Apr 19 15:27:06.279: PPPoE 0: I PADO  R:346e.9d92.ad8c L:0013.c341.7bf3 Fa0/1
146476: Apr 19 15:27:06.279: PPPoE 0: I PADO  R:ac60.b65f.4c01 L:0013.c341.7bf3 Fa0/1
146477: Apr 19 15:27:08.171:  PPPOE: we've got our pado and the pado timer went off
146478: Apr 19 15:27:08.171: OUT PADR from PPPoE Session
146479: Apr 19 15:27:08.363: PPPoE 2: I PADS  R:346e.9d92.8a2e L:0013.c341.7bf3 Fa0/1
146480: Apr 19 15:27:08.363: IN PADS from PPPoE Session
146481: Apr 19 15:27:08.363: %DIALER-6-BIND: Interface Vi7 bound to profile Di5
146482: Apr 19 15:27:08.363: PPPoE: Virtual Access interface obtained.
146483: Apr 19 15:27:08.363: PPPoE : encap string prepared
146484: Apr 19 15:27:08.367: [0]PPPoE 2: data path set to PPPoE Client
146485: Apr 19 15:27:08.371: %LINK-3-UPDOWN: Interface Virtual-Access7, changed state to up
146486: Apr 19 15:27:08.375: ppp3 PPP: Using AAA Unique Id = 11
146487: Apr 19 15:27:08.375: Vi7 PPP: Authorization NOT required
146488: Apr 19 15:27:08.375: Vi7 PPP: Using dialer call direction
146489: Apr 19 15:27:08.375: Vi7 PPP: Treating connection as a callout
146490: Apr 19 15:27:08.375: Vi7 PPP: Session handle[19000003] Session id[3]
146491: Apr 19 15:27:08.567: Vi7 CHAP: I CHALLENGE id 1 len 32 from "bng2.th-lon"
146492: Apr 19 15:27:08.567: Vi7 PPP: Sent CHAP SENDAUTH Request
146493: Apr 19 15:27:08.567: Vi7 PPP: Received SENDAUTH Response FAIL
146494: Apr 19 15:27:08.567: Vi7 CHAP: Using hostname from interface CHAP
146495: Apr 19 15:27:08.567: Vi7 CHAP: Using password from interface CHAP
146496: Apr 19 15:27:08.567: Vi7 CHAP: O RESPONSE id 1 len 34 from "<myaccount>@zen"
146497: Apr 19 15:27:08.678: Vi7 CHAP: I SUCCESS id 1 len 43 msg is "CHAP authentication success, unit 18191"
146498: Apr 19 15:27:08.686: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access7, changed state to up
However on the C887 it never gets past the PADI, i.e. no PADO ever comes back:
*Apr 19 13:13:39.872:  Sending PADI: Interface = FastEthernet3
*Apr 19 13:14:12.132:  padi timer expired
*Apr 19 13:14:12.132:  Sending PADI: Interface = FastEthernet3
*Apr 19 13:14:44.400:  padi timer expired
Relevant snippets of my config are:
interface FastEthernet3
description Zen BT
switchport access vlan 101
no ip address
pppoe enable group global
pppoe-client dial-pool-number 2
no cdp enable
interface Vlan101
ip address dhcp
ip virtual-reassembly in
zone-member security OUT-ZONE
interface Dialer2
description Zen PPPoE via FE3
ip address negotiated
no ip unreachables
ip mtu 1452
ip nat outside
encapsulation ppp
ip tcp adjust-mss 1452
dialer pool 2
dialer-group 2
ppp authentication chap callin
ppp chap hostname <myaccount>@zen
ppp chap password 0 <myclearpass>
ppp direction callout
ppp ipcp address accept
no cdp enable
The VLAN 101 is more for if I ever connect Zen to the VDSL port (I think BT infinity needs it to be 101, but I'm not sure about Zen, which uses BT network).
I am running ZBF on both devices and occassionally saw in the logs DHCP packets being dropped (and I'm thinking the PPPoE dialer must be sending DHCP to the ISP end) but not correlated to the PADI sending.
I can't see much different between the C1841 & the C887 (other than the extra VLAN config that the 887 supports).
I'm running 15.4(3)M1 on the C887. Unfortunately it went EOL last August and I didn't download the latest versions (I did have a 3 year SmartNet contract though which went past the end of August so possibly I could ring Cisco to ask for a later version if there's some kind of incompatibility/bug, though I suspect it's an issue in my configuration).
I've run out of ideas now, so all suggestions welcome! TIA!
Simon
0 Replies 0
