Failover configuration on cisco 2801 router
Ajay Kumar Pal
Hi all,
I am bit confused, that how can i confiure the router in this situation.
I have to configure failover on both router. if one get fail then the other router should be dial.
Physical connection
  • •1.        Two routers (Cisco 2801) are connecting with splitter through RJ 11 port.
  • •2.        Only one ISP link is coming in splitter.
Requirement
  • 1.       As per as customer requirement. He wants redundancy with in both 2 routers. If one goes down then the other router come up.
Here is the configuration
2801_R1
interface FastEthernet0/0
description $ETH-SW-LAUNCH$$INTF-INFO-FE 0$
no ip address
duplex auto
speed auto
interface FastEthernet0/1
description ***Connected to CORE_SW*****$ES_LAN$
ip address 172.20.3.2 255.255.255.0
ip nat inside
ip virtual-reassembly
ip tcp adjust-mss 1412
duplex auto
speed auto
interface ATM0/3/0
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0/3/0.2 point-to-point
description $ES_WAN$
pvc 8/35
  encapsulation aal5mux ppp dialer
  dialer pool-member 1
interface Dialer2
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname inovest
ppp chap password 7 03124F1F0404375F4A
ppp pap sent-username inovest password 7 1401061F0E0F3C3820
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer2
And same configuration on 2801_R2 router.  I am planing to do HSRP on our lan network (2801R1,2801R2 ehternet interface which connected to switch). from switch i will create two default route with (next hope) virtual ip address.
6 Replies 6
paolo bevilacqua
You can't do 'splitter' on ADSL cable. You can place an A/B switch on it.
You should not worry either about router failure, that is a very rare event. You will have 1000 times more circuit failures than router failures.
thank you for your time and considration.
Do you have any kind of document, where can i get more information regard A/B Switch.
In that Q. the RJ11 cable is directlly connected to cisco router 2801.
Just go to any phone equipment shop to get one.
However since it requires manual operation, it's not much advantegeous than replace cable in socket.
I agree you should be more worried about circuit than router failure. However, any inbound cable pair can be "split" into two outbound pairs. Just terminate the inbound pair on a block and attach two outbound leads to each. As long as only one is active at any time it should work fine.
Thank you,
          I got the point. so we can splitt the connection with 2 router. at a time only 1 router is active.
Hi Paolo & Jeff,
I have done the configuration on both router, but i am faceing one problem.
Here is the configuration and topology....
IN_RTR1#sh run
Building configuration...
Current configuration : 2826 bytes
version 12.4
service password-encryption
hostname IN_RTR1
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
enable secret 5 $1$AOUV$EDGCVV46e1U0vlxX4dJln0
enable password 7 151B0F0905390B757A60
no aaa new-model
dot11 syslog
ip cef
no ip domain lookup
ip name-server 217.17.233.49
username admin privilege 15 secret 5 $1$r9oG$cP3yE.5YBNkGh4jUQ6XBZ.
archive
log config
  hidekeys
no ip address
duplex auto
speed auto
ip nat inside
duplex auto
speed auto
standby 1 ip 172.20.3.29
standby 1 priority 104
standby 1 preempt
standby 1 track ATM0/3/0 20
interface ATM0/3/0
no ip address
pvc 8/35
interface Dialer2
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp chap password xxxxxxxxxxxxxx
ppp pap sent-username inovest password xxxxxxxxxxxxxxxxxx
router eigrp 100
redistribute connected metric 10000 1000 255 1 1500 route-map WAN
network 172.20.3.2 0.0.0.0
no auto-summary
ip http server
ip http access-class 23
ip http authentication local
no ip http secure-server
ip nat inside source list 1 interface Dialer2 overload
ip nat inside source static tcp 172.20.3.4 3389 interface Dialer2 3389
ip nat inside source static tcp 172.20.3.5 25 interface Dialer2 25
ip nat inside source static tcp 172.20.3.6 443 interface Dialer2 443
ip nat inside source static tcp 172.20.3.7 80 interface Dialer2 80
ip nat inside source static udp 172.20.3.1 500 interface Dialer2 500
ip nat inside source static udp 172.20.3.1 4500 interface Dialer2 4500
ip nat inside source static tcp 172.20.3.8 21 interface Dialer2 21
access-list 1 permit any
access-list 23 permit any
dialer-list 1 protocol ip permit
route-map WAN permit 10
match interface ATM0/3/0
route-map WAN permit 20
control-plane
alias exec s show ip int brief
line con 0
exec-timeout 0 0
logging synchronous
line aux 0
line vty 0 4
privilege level 15
password 7 11001D0016012B5D5679
login local
transport input telnet
line vty 5 15
privilege level 15
login local
scheduler allocate 20000 1000
end
Elittechno#sh run
Current configuration : 5129 bytes
! Last configuration change at 16:46:26 UTC Mon Mar 18 2013
version 15.2
hostname Elittechno
boot-start-marker
boot-end-marker
enable secret 4 hIzNgSRpr0rDiY97HmOKiEhZwCZuL6XQvtN35SR.FAY
enable password elitetechno@123
no aaa new-model
ip cef
no ip domain lookup
no ipv6 cef
crypto pki trustpoint TP-self-signed-3061308914
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3061308914
revocation-check none
rsakeypair TP-self-signed-3061308914
crypto pki certificate chain TP-self-signed-3061308914
certificate self-signed 01
  3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 33303631 33303839 3134301E 170D3133 30323031 31323136
  35395A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D33 30363133
  30383931 3430819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100DA12 E4F228DB C18219AB 9269038A AA9FA213 EE56A1E4 BCE926C3 DF933A36
  FF85C900 55044F88 E60B36B3 91D9FC34 CA20AF06 B82F3048 9290B196 AC4BB5E7
  AB6A8621 C8442EF7 4A34E886 D9AFB6E2 0F82F63C 751201CE 9C328BAE 148D6C86
  87E6E4F5 164D18B2 DE7D28AA 76D7AB63 9D510C30 97C9F457 E4876C1F 0739B747
  7C870203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
  551D2304 18301680 140A365B FCC0127A A364BA2C 6E8C1C71 54C0DDC6 2E301D06
  03551D0E 04160414 0A365BFC C0127AA3 64BA2C6E 8C1C7154 C0DDC62E 300D0609
  2A864886 F70D0101 05050003 818100CB 4E92BAB1 483F7213 DE4EE342 2A6DE442
  3786FD0F 78C098BA E7876CF2 A3399268 39DBFD9B A18BC8F0 AA4C232C D7D21829
  0E2BB8EA 7781CCDB 8E53AD31 EB9AAF2C ABB8C00E CA7FC37B 8A1D4B18 E149338B
  9B66F263 E7A30648 E25EF0F7 6DBFFB5C 4C5ABD5A 9D1150BD B823994A 8E649D95
  EDEC0008 2945CD6B 154B92A6 54CA19
        quit
license udi pid CISCO2901/K9 sn FCZ1705C593
username Elittechno_gokul privilege 15 password 0 elitetechno@123
username Elitetechno password 0 elitetechno@123
redundancy
csdb tcp synwait-time 30
csdb tcp idle-time 3600
csdb tcp finwait-time 5
csdb tcp reassembly max-memory 1024
csdb tcp reassembly max-queue-length 16
csdb udp idle-time 30
csdb icmp idle-time 10
csdb session max-session 65535
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address 172.20.3.10 255.255.255.0
ip nat inside
ip virtual-reassembly in
standby 1 preempt
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface ATM0/0/0
no ip address
interface ATM0/0/0.2 point-to-point
pvc 8/35
interface Dialer2
ip nat outside
no ip virtual-reassembly in
encapsulation ppp
dialer pool 1
dialer-group 1
ppp chap password xxxxxxxxxxxxxxxxxxxxx
ppp pap sent-username inovest password xxxxxxxxxxxxxxxxxxx
router eigrp 100
network 172.20.3.10 0.0.0.0
ip http server
control-plane
banner exec ^CC
This is ADSL Router cisco 2901
^C
banner login ^CC
Elite Technologies Middle East
^C
line con 0
exec-timeout 0 0
logging synchronous
login local
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
privilege level 15
login local
transport input all
line vty 5
login local
transport input all
end
HSRP is working, 2801 router is active and 2901 router is standby. And i given one static route on firewall with hsrp virtual ip address.
Now problem is, When i am going to shutdwon interface (ATM0/3/0) manually on active router, then the standby router is become active, and user are able to access internet. it means the secandary router is dailing the connection to isp.
But when i am doing switch off the active router, then standby router is coming active but it is not able to initiate the connection with isp the debug massage is          cannot replce the call, no string is set.        if i am removing the RJ 11(ATM0/3/0) coble from the active router, which is currenty switch off (no power on the 2801 router). Then the standby router is able to initiate the connection with isp.
