Failover ISP setup - can't ping Internet from standby interface
DazOG
I have a working "ip sla" setup, following the instructions here: https://www.cisco.com/c/en/us/support/docs/ip/ip-routing/200785-ISP-Failover-with-default-routes-using-I.html and elsewhere.
The problem I've got is that in the example above the test IP is the next hop router, which is across the link being monitored.  In my case, the next hop is in the same server rack so it is pointless to monitor it to determine if the line is up or not, because it always will be unless the NTE is powered off.
If I try and ping e.g. 8.8.8.8 by doing:
ping 8.8.8.8 source-interface GigabitEthernet0/0/0
or
ping 8.8.8.8 source-ip 123.0.0.1
(where 123.0.0.1 is the IP of GigabitEthernet0/0/0)
..I don't get any reply, unless i am already routing via the next-hop to Gi0/0/0.  If i am routing via the 2nd ISP, NAT'ing to a different block of public IPs, then I can't access the Internet via the 1st ISP.
Just to reiterate - the NTE is in the same rack as my equipment, i.e. 123.0.0.2 is in the same rack as 123.0.0.1, so it is pointless to use 123.0.0.2 as a test IP for reachability.
Any thoughts?  I feel like this is a NAT issue, but not sure how I can fix it?
Use
Ip route 8.8.8.8 255.255.255.255 isp interface(you want to track) permanent
This command force router to use specific isp and make track correct work.
MHM
Use
MHM
DazOG
Thanks. I guess that would make that IP (Google’s DNS) inaccessible via whichever ISP is currently being used, wouldn’t it?
That correct but
We usually use two dns ip 8.8.8.8 and  8.8.4.4
And also if interface down this static route is remove from rib.
So it have really some disadvantages.
MHM
DazOG
Thanks.  I've chosen another public DNS server that we aren't using for anything else anyway.
