Failover Switch-Server
Fotiosmark
hello team,
I was wondering, I don't think it can be done with the equipment I have but I thought I might ask.,
Simple design,
Cisco1941 - Switch SG200 - Server ESXi
The server is connected on a port, belonging to Vlan 5 - 192.168.5.1 and goes out on internet through trunk.
Now the managers asked me, with the existing equipment if I can make another Vlan, vlan 20 with IP 192.168.5.252 so they can raise VMs in ESXi with 192.168.5.252 and the other halfs with 192.168.5.1.
I know that can't be done since its on same subnet...
Is there another way to achieve that? 2 gateways on same switch? or would I need another swtich with hsrp capabilties?
Many thanks
balaji.bandi
HA / Resilience means 2 device. if you do not have 2 Device, then you will not get HA/Resilience features.
Personally It  not make any sense create 2 VLAN in same device and deploy as HA.
Not sure this is make sense  for you ?
BB
i thought so... :)
May Suggest Manager that buy another setup of equipment for HA, if the business like more Resilience and no downtime acceptable.
This is again business case with CAPEX and OPEX.
BB
