Faulty NM-4A/S?
Kevin Brennan
Hi All,
I'm having a problem with a NM-4A/S and a 2620 router.
The NM-4A/S is identified in the 2620 as a NM-4T (which is unsupported). If I try it in a 2651XM it coms up as an unknown port adaptor.
The IOS on the 2620 is 12.3(19a) and the 2651XM is 12.4(18). According to the following link, the NM-4A/s should be supported.
http://www.cisco.com/en/US/products/hw/routers/ps274/products_tech_note09186a00800a93f1.shtml
As a test, I put the same NM-4A/S into a 3620, running 12.1 and it comes up as a Mueslix-4T
Now, this NM was sitting in a drawer for a long time (and may have come via eBay) Is it possible that an NM-4A/S could actually be a NM-4T? or could it be faulty? The back plate of the card does clearly say NM-4A/S
Thanks for any input.
Kevin
srinivas_816
As per the document the Card is supported by the cisco 2600 XM series only
when you give the sh ver
cisco 2621XM (MPC860P) processor (revision 0x301) with 118784K/12288K bytes of memory.
Hi Paila,
I think you may have misunderstood me.
I know that the NM-4T is not supported in the 2600 series, but the card I installed was marked as being a NM-4A/S which is supported in the 2600 series.
Kevin
