finger service not getting enabled in router
i tried enabling 'ip finger' command in my router, but it isnt' working, please help
Router#config terminal
Enter configuration commands, one per line. End with CNTL/Z.
Router(config)#ip finger
^ % Invalid input detected at '^' marker.
balaji.bandi
what is the model of the device and can you post-show version output?
BB
5 Replies 5
balaji.bandi
BB
Joseph W. Doherty
I'm wondering whether 1) command not supported on your platform, or 2) security on the device blocks the command.
Mark Elsen
 Ref : https://www.cisco.com/c/en/us/support/docs/ip/access-lists/13608-21.html
  Issue the no ip finger global configuration command in order to disable Finger service. Cisco IOS software releases later than 12.1(5) and 12.1(5)T disable this service by default.
 - It seems that quite correctly and according to best security practices in more recent IOS versions this feature is disabled.
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Hi All,
Thanks for the great help :) I just figured it doesn't work in CISCO packet tracer.
For Packet Tracer, that's very likely.
