Firewall configuration packet tracer
networkjock
I want to connect two LAN networks through a ASA firewall allowing a host on one network to ping a host on the other and allow all mail and web traffic between the two networks. How do i set up the firewall configuration to allow traffic both in and out of both LANs.
Please can you help!?
13 Replies 13
post your zipped.pkt file...
Attached file to zip
this is the file that I sent you. What is not working ? You have to wait for a few minutes after opening the file in order for everything to converge.
I can ping 192.168.10.2 and 192.168.10.3 from 192.168.30.2 (the PC)...
Sorry attached the wrong file
there is no ASA in the project you have attached...what is the objective ?
I would like to add an ASA firewall between the two networks, HQ and Branch. I would still like to be able to send/receive emails and access the web server from all end-point devices.
I cannot edit the devices, configs are locked. Try to put the firewall in between the routers and use the config below. Make sure to configure the corresponding router interfaces with the next hop IP addresses that the firewall uses for the static routes. On the router, configure static default routes pointing to the firewall's corresponding interface.
In Packet Tracer, use the ASA5506-X, not the 5505.
ASA Version 9.6(1)
hostname ciscoasa
names
interface GigabitEthernet1/1
description Link to AKCBranchRouter
nameif inside
security-level 100
ip address 192.168.0.1 255.255.255.0
interface GigabitEthernet1/2
description Link to AKCHQRouter
nameif outside
security-level 0
route outside 10.0.0.0 255.0.0.0 192.168.1.2
route inside 30.0.0.0 255.0.0.0.0 192.168.0.2
access-list ICMP_HTTP_SMTP_POP3 extended permit icmp any any echo-reply
access-list ICMP_HTTP_SMTP_POP3 extended permit tcp any any eq www
access-list ICMP_HTTP_SMTP_POP3 extended permit tcp any any eq pop3
access-list ICMP_HTTP_SMTP_POP3 extended permit tcp any any eq smtp
access-group ICMP_HTTP_SMTP_POP3 in interface outside
class-map inspection_default
match default-inspection-traffic
policy-map global_policy
class inspection_default
inspect dns
inspect http
inspect icmp
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
service-policy global_policy global
telnet timeout 5
ssh timeout 5
I have tried the config suggested but I am still finding difficulties. I have attached the file below
I still cannot access the routers, can you either grant access or post the running configs of both routers ?
The routing on your firewall is incorrect:
route outside 10.0.0.0 255.255.255.0 192.168.1.2 1
route outside 30.0.0.0 255.255.255.0 192.168.0.2 1
needs to be:
route inside 30.0.0.0 255.255.255.0 192.168.0.2 1
make sure that on your routers, the below is configured:
AKCBranchRouter
ip route 0.0.0.0 0.0.0.0 192.168.0.1
AKCHQRouter
ip route 0.0.0.0 0.0.0.0 192.168.1.1
Here is a working config for the ASA5506-X in Packet Tracer. I have also included the zipped project file...
ASA Version 9.6(1)
hostname ciscoasa
names
nameif inside
security-level 100
ip address 192.168.10.1 255.255.255.0
nameif outside
security-level 0
ip address 192.168.20.1 255.255.255.0
route outside 0.0.0.0 0.0.0.0 192.168.20.2 1
inspect dns
inspect http
inspect icmp
parameters
telnet timeout 5
ssh timeout 5
ciscoasa#
I'm experiencing the same issues myself, may I DM you?
Thanks!
