Fix for CVE-2016-2183 (SWEET32) vulnerability
gryffindor
Our vulnerability scan found that all 4948 and 3750 switches are having a vulnerability of "SSH Birthday attacks on 64-bit block ciphers (SWEET32)".
However, the other models like 3650/3850/4500 are not having this vulnerability. Could anyone help me, why only a few models are affected and what can I do to fix this.
The bug search on cisco suggested there is no workaround which seems strange - https://quickview.cloudapps.cisco.com/quickview/bug/CSCvf45855
7 Replies 7
Leo Laohoo
Upgrade the firmware.
Hi Leo,
switch is already on recommended ios i.e. Version 15.2(4)E10.
I was wondering, if there were some config changes that can be made.
Compared to what version?
Seriously, I'd be more interested to know if VStack is still enabled or not.
Hello @gryffindor ,
I have tried to use the following command
switch(config)#ip ssh client algorithm encryption ?
  3des-cbc    Three-key 3DES in CBC mode
  aes128-cbc  AES with 128-bit key in CBC mode
  aes128-ctr  AES with 128-bit key in CTR mode
  aes192-cbc  AES with 192-bit key in CBC mode
  aes192-ctr  AES with 192-bit key in CTR mode
  aes256-cbc  AES with 256-bit key in CBC mode
  aes256-ctr  AES with 256-bit key in CTR mode
I have used
ip ssh client algo aes256-ctr .
But after some tests I have seen it is not really effective as it does not prevent the use of DES or 3DES cypher so I would say there is no workaround.
Hope to help
Giuseppe
Hi Giuseppe,
Thanks. I also tried the same but it didn't help.
I had one more query if you could help. I was looking to fix weak key exchange algorithms on my switch. I could do it on 3650 switch with command
ip ssh server algorithm kex diffie-hellman-group14-sha1
but this command is not accepted on 4948 and 3750 switches. Is there any thing that I am missing.
As far as weak ciphers, disable SSHv1 and TLS versions 1.0/1.1. To disable SSHv1 and remove Cipher Block Chain and 3Des ciphers you should be able to do the following in Global Config mod:
ip ssh version 2 !disable V1
ip ssh server algorithm encryption aes256-ctr aes128-ctr
ip ssh server algorithm mac hmac-sha1
no ip ssh server algorithm mac hmac-sha1-96
Has this worked? I'm also facing this issue on my 3750.
