Local Preference attribute on outbound routes
ThomasD86
I am working with the topology in the image. Router A, B and C have an
iBGP
neighborship. B and C announce a
default route
towards A, Router A should prefer the default advertised from B to the one advertised from C.
This is the configuration I have on routers,
Router A:
 neighbor 2.2.2.2
  remote-as 65535
  description *** TO ROUTER B ***
  update-source Loopback0
   route-policy BGP_PASS_ALL in
   route-policy BGP_PASS_ALL out
   next-hop-self
   soft-reconfiguration inbound always
neighbor 3.3.3.3
  remote-as 65535
  address-family ipv4 unicast
next-hop-self
Router B:
neighbor 1.1.1.1 activate
 neighbor 1.1.1.1 next-hop-self
 neighbor 1.1.1.1 default-originate
 neighbor 1.1.1.1 soft-reconfiguration inbound
 Router C:
neighbor 1.1.1.1 route-map LP-50 out
On router C, I have configured this route-policy:
route-map LOCAL-PREF-90, permit, sequence 10
  Match clauses:
    ip address prefix-lists: DEFAULTROUTE
  Set clauses:
    local-preference 90
  Policy routing matches: 0 packets, 0 bytes
ip prefix-list DEFAULTROUTE
ip prefix-list DEFAULTROUTE: 1 entries
   seq 5 permit 0.0.0.0/0
This however doesn't seem to work and router A will receive the
default route
from C with a local pref value of 100 rather than 90.
Only when configuring a policy on router A the local preference value will be applied. Does local preference only work in the inbound direction?
Harold Ritter
Hi @ThomasD86 ,
The
default route
originated via the
default-originate
command is not subjected to the outbound
rroute-map
. Try applying the following configuration instead.
neighbor 1.1.1.1 default-originate route-map LP90
route-map LP90 permit 10
set local-preference 90
Harold Ritter
Hi @ThomasD86 ,
The
default route
originated via the
default-originate
rroute-map
Thank you Harold,
this worked perfectly.
Have a great day!
