02-01-2017
08:19 PM
- last edited on
03-25-2019
03:48 PM
by
ciscomoderator
Hi Guys,
Need your assistance. I created topology below. I created HSRP on R12 and R13 then EIGRP everywhere. After everything is configured. The adjacency between R12 and R14 keeps coming up and down. I noticed that all packets are being routed to R13. All interfaces have equal speed (10mbps / half duplex). I'm suspecting split-horizon but not 100% sure.
Here are the configurations
R12
interface FastEthernet0/0
ip address 192.168.10.2 255.255.255.248
speed auto
duplex auto
standby 1 ip 192.168.10.1
standby 1 priority 110
standby 1 preempt
interface Serial0/0
no ip address
shutdown
clock rate 2000000
interface FastEthernet0/1
ip address 192.168.10.9 255.255.255.248
speed auto
duplex auto
router eigrp 1
network 192.168.10.0 0.0.0.7
network 192.168.10.8 0.0.0.3
no auto-summary
R13
ip address 192.168.10.3 255.255.255.248
speed auto
duplex auto
standby 1 preempt
interface Serial0/0
no ip address
shutdown
clock rate 2000000
ip address 192.168.10.22 255.255.255.252
speed auto
duplex auto
router eigrp 1
network 192.168.10.20 0.0.0.3
no auto-summary
R14
ip address 192.168.10.13 255.255.255.252
speed auto
duplex auto
interface Serial0/0
no ip address
shutdown
clock rate 2000000
ip address 192.168.10.10 255.255.255.252
speed auto
duplex auto
router eigrp 1
network 192.168.10.12 0.0.0.3
no auto-summary
R15
ip address 192.168.10.18 255.255.255.252
duplex auto
speed auto
interface Serial0/0
no ip address
shutdown
clock rate 2000000
ip address 192.168.10.21 255.255.255.252
duplex auto
speed auto
router eigrp 1
network 192.168.10.16 0.0.0.3
no auto-summary
R11
interface Loopback0
ip address 11.11.11.11 255.255.255.0
ip address 192.168.10.14 255.255.255.252
speed auto
duplex auto
interface Serial0/0
no ip address
shutdown
clock rate 2000000
ip address 192.168.10.17 255.255.255.252
speed auto
duplex auto
router eigrp 1
network 11.11.11.0 0.0.0.255
no auto-summary
Solved! Go to Solution.
02-01-2017 10:25 PM
What I have observed from the configuration that you have miss-configured R12 Fa 0/1. Its subnet mask should be 252.
ip address 192.168.10.9 255.255.255.248.
It should be 255.255.255.252.
You have also advertised network 192.168.10.8 0.0.0.3 in Eigrp.
Make these changes if can help.
Regards'
02-01-2017 10:25 PM
Regards'
02-01-2017 11:37 PM
Wow!! I completely missed it. I've been troubleshooting this for a day. Darn!! Thanks for everyone's help..appreciate it!
02-01-2017 11:45 PM
02-01-2017 10:33 PM
Set your interface speed and duplex manually and check your Subnet configuration. Your problem will
Reards,
Deepak Kumar
