flash and dram size
Could some one pl's help me to find out my 3560 switch DRAM and flash size
#sh version
Cisco IOS Software, C3560E Software (C3560E-IPBASEK9-M), Version 15.0(2)SE, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Fri 27-Jul-12 23:44 by prod_rel_team
ROM: Bootstrap program is C3560E boot loader
BOOTLDR: C3560E Boot Loader (C3560X-HBOOT-M) Version 12.2(53r)SE2, RELEASE SOFTWARE (fc1)
COLITT-OOB-SW02 uptime is 3 weeks, 3 days, 5 hours, 0 minutes
System restarted at 22:34:38 MDT Sat Sep 15 2012
System image file is "flash:/c3560e-ipbasek9-mz.150-2.SE.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Level: ipbase
License Type: Permanent
Next reload license Level: ipbase
cisco WS-C3560X-48 (PowerPC405) processor (revision A0) with 262144K bytes of memory.
Processor board ID FDO1513Z0TJ
Last reset from power-on
7 Virtual Ethernet interfaces
1 FastEthernet interface
52 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
#sh flash
Directory of flash:/
    2  -rwx         976  Sep 28 2012 20:00:06 -06:00  vlan.dat
  444  -rwx        3833  Sep 28 2012 20:06:35 -06:00  private-config.text
    3  -rwx        9841  Sep 28 2012 20:06:35 -06:00  config.text
    4  -rwx        3096  Sep 28 2012 20:06:35 -06:00  multiple-fs
    5  -rwx    19678395  Sep 10 2012 16:29:43 -06:00  c3560e-ipbasek9-mz.150-2.SE.bin
    6  -rwx    12752912   Oct 3 2012 12:34:04 -06:00  c3560-ipservicesk9-mz.122-55.SE6.bin
    7  drwx         512  Feb 28 1993 17:14:53 -07:00  c3560e-universalk9-mz.122-55.SE1
57671680 bytes total (6986752 bytes free)
COLITT-OOB-SW02#
6 Replies 6
Sandeep Choudhary
sh flash: it will show the flash size.
The line cisco WS-C3560X-48 (PowerPC405) processor (revision A0) with (x/y)262144K bytes of memory.
bytes of memory” tells how much RAM in your device. The first parameter  (x) specifies how much Dynamic RAM (DRAM) in your device while the  second parameter (y) indicates how much DRAM is being used.
but in your case total DRAM size is 262144K.
Please rate if it helps.
Hi Sandeep ,
Thanks for prompt reply.
If you calculate it's showing as 55 MB. Is it really possible .
Disclaimer
The Author of this posting offers the information contained  within this posting without consideration and with the reader's  understanding that there's no implied or expressed suitability or  fitness for any purpose. Information provided is for informational  purposes only and should not be construed as rendering professional  advice of any kind. Usage of this posting's information is solely at  reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
suryakant chavan wrote:
Hi Sandeep ,
57671680 (used) + 6986752 (free) = 64658432 (total) or 64 MB flash.
I want to upload to a IOS which required 256 DRAM and 64 MB flash.
So will it support this requirement.
Yes it can be 64MB........some time u can see 128MB.
what is the size of new ios?????
as per your sh flash output, it seems that you will run the new ios "Ipservices". ??
if you dont have enough space then:
You should delete the bin file of previous version IOS from flash by using  delete /f /r flash:filename.bincommand.  Deleting files manually will not be a problem(I have tested several  times before - you can backup file incase of failure) Then you can  upload file to a flash memory and set it as a boot file by using boot system switch all flash:......command
I want to ask, is it possible if I want to upgrade the DRAM on Cisco ISR 4451 (before 4G) to 16G. Is there any association with Flash Memory?
Thanks and Regards,
Bella
