03-03-2010 01:20 AM - edited 03-04-2019 07:41 AM
Hi Experts
How to release space from flash for deleted items
CompactFlash directory:
File Length Name/status
1 58084804 c2800nm-adventerprisek.bin
2 69 syncinfo.xml [deleted]
3 1879 SIPDefault.cnf [deleted]
4 3579 softkeyDefault_kpml.xml [deleted]
5 3613 softkeyDefault.xml [deleted]
6 69 syncinfo.xml [deleted]
7 1878 SIPDefault.cnf [deleted]
8 3579 softkeyDefault_kpml.xml [deleted]
9 3613 softkeyDefault.xml [deleted]
10 5134 7970-71-75-Background-readme-v1.txt [deleted]
11 2593969 APPS-1.2.1.SBN [deleted]
12 2925555 apps11.8-4-1-23.sbn [deleted]
13 596680 apps31.8-4-1-23.sbn [deleted]
[64225276 bytes used, 0 available, 64225276 total]
62720K bytes of ATA CompactFlash (Read/Write)
03-03-2010 01:23 AM
Run the "squeeze" command in your router
Router#squeeze flash:
Karuppu
03-03-2010 01:41 AM
Thanks it worked
03-03-2010 01:44 AM
If you find the post is helpful, please rate it.
I am glad to help u
Karuppu
