Forward GRE over NAT to firewall
rasoftware
I have a 1800 router at the network perimeter with a public address and private on the inside. Behind that I have a PIX with a private address on the outside interface. PIX uses the router as a gateway. I have a problem in that I can't forward PPTP/GRE traffic through to the PIX. I add port forward 1723 TCP/UDP on the router to the PIX but this doesnt seem enough. I also need GRE I guess which is portless. I manaage to create inound IPSEC tunnels because I can map UDP 500 and encap 4500 UDP. Does anyone know how to do the same for inbound PPTP tunnels?
