Forward Port Range with one Public IP.
olafmarcos
Hi Everybody:
What is the way to forward a port range to internal ip address and don't break the router internet access?
My situation:
I've a SHDSL connection with 878 (IOS version 12.4) and one public IP.
If I configure:
"ip nat inside source static <private ip> <public ip> route-map VOIP extendable" to do a port range forwarding, the router lost the internet access.
What is the correct way?
Thanks and best regards,
Olaf
bstremp
Level 2
Level 2
think any router allows forwarding of a port to a LAN IP Address. You can use any router.
For more information please click following URL:
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_tech_note09186a0080094831.shtml#behindmask
I thought any router does, but in practice, cisco routers need at least 2 public ip addresses for doing. Don't you think is a waste of public ip addresses?
Do you have a working config?
