Forward traffic from subnet to another on C3750
gabecz
hi guys thanks for your suggestions in advance
i just reconsidered my whole message. after trying some things. i think i need to set up acl but i'm far from good at it.
what would be the ip access-list extended or access-list lines that'd allow me to have network on the windows machines on this setup?
i can't share the bgp and neighbor lines of the config but here is the beginning of the config and the nic settings
i rolled back to a plain setup for now.
sh ru on cisco-a
version 15.1
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
service compress-config
hostname cisco-a
boot-start-marker
boot-end-marker
logging discriminator EXCESS severity drops 6 msg-body drops EXCESSCOLL
logging buffered 50000
logging console informational
no logging monitor
no aaa new-model
clock timezone pst -8 0
clock summer-time pdt recurring
no ipv6 cef
ipv6 multicast rpf use-bgp
no ip icmp rate-limit unreachable
no ip domain-lookup
no ip cef
spanning-tree mode pvst
vlan internal allocation policy ascending
ip tcp synwait-time 5
interface Loopback0
ip address 123.123.1.7 255.255.255.255
interface Ethernet0/0
description Internet Access
no switchport
ip address dhcp
no ip redirects
no ip proxy-arp
no cdp enable
interface Ethernet0/1
description iBGP peering link to cisco-b
no switchport
ip address 172.16.13.0 255.255.255.254
no ip redirects
interface Ethernet0/12
no switchport
ip address 123.123.13.246 255.255.255.252
no ip redirects
no ip http server
route-map A_to_B permit 10
match ip address 100
set metric 100
route-map set-med permit 10
set metric 80
snmp-server community cispublic RO 15
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
end
7 Replies 7
You need in Routet two NAT overload
One for each host subnet
MHM
can you post the configs of both 3750 switches ?
gabecz
updated my post with the config. cisco-b is identical to this but the 3 ip addresses. loopback 8 instead of 7, e0/1 1 instead of 0, and 242 instead of 246 on e0/12 is all the difference. thanks for any suggestion
gabecz
basically from windows i can ping the switch interface that connects to opnsense, but not opnsense and vice versa from opnsense i can ping the interface on the swtich that connects to the windows machine but not the windows machine.
isn't this one of those things where you need to have an access list and do ip access-group X in and ip access-group Y out on these interfaces? sorry for my kitchen language.
post the full running configs of both switches and the router...
share traceroute from window to opensense
MHM
Hello
@gabecz wrote:
from windows i can ping the switch interface that connects to opnsense, but not opnsense and vice versa  i can ping the interface on the swtich that connects to the windows machine but not the windows machine.
Do you have the windows software firewall on?- if so by default windows negates echo-reply (ping reply)
Add an allow rule for icmp echo-reply in the fw or temporally turn off the fw and test again
Kind Regards
Paul
