forwarding in cisco router 800 series
expertcisco780
hi freinds,
I uses cisco router C881 but it is not support forwarding  in GUI, can you tell me what software can i install to accses GUI?
also what is the CLI command to forward ip /ports.
thanks&regards
Mark Malone
You can use SDM if not your not familiar with cli , you need to use NAT to allow port forwarding
http://www.cisco.com/c/en/us/support/docs/cloud-systems-management/router-security-device-manager/71305-basic-router-config-sdm.html
Mark Malone
Dan Lukes
Feedback forum is dedicated to other topics.
Moved to WAN, Routing and Switching
