Forwarding port 80 not working
Phill Johntony
I setup a LAMP server and can connect to it locally, I tried forwarding port 80 to the apache server but it is not working.
interface GigabitEthernet0/0
description **WAN**
ip address dhcp
ip nat outside
ip virtual-reassembly in
interface GigabitEthernet0/1
description **LAN**
ip address 10.0.0.1 255.255.255.0
ip nat inside
ip nat inside source list INSIDE_NAT_ADDR interface GigabitEthernet0/0 overload
ip nat inside source static tcp 10.0.0.12 80 interface GigabitEthernet0/0 80
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0
ip access-list standard INSIDE_NAT_ADDR
permit 10.0.0.0 0.0.255.255
Not sure what is wrong, I've scoured the internet for an hour and it all looks good to me.
Hi from where are you doing this test, from an outside loaction or from an inside location ?
I tried it from my location and I got a Web page with "Woot".
If you try from inside by referencing the outside IP you will be performing NAT hairpinning and this is not supported with classic NAT so you'll have to use NAT NVI to test this from inside.
To do so:
1) replace ip nat inside and ip nat outside commands by ip nat enable
2) replace static inside nat command by ip nat source static .........( you omit the keyword inside)
3) no ip redirect on the WAN interface
Alain
9 Replies 9
Abzal
Level 7
Level 7
The config looks correct for me.
Try to use another port of web server instead of 80. I'm not sure but ISP might be blocking the 80 port. And do you have static IP for web server or Dynamic DNS?
Hope it will help.
Best regards,
Abzal
Best regards,
Abzal
cadet alain
You should change your default route like this:
no ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0
ip route 0.0.0.0 0.0.0.0 dhcp
Try to get to your server from the WAN and if it is still failing post output of sh ip nat translation | i 10.0.0.12
Alain
Hello
Just like to add also that your config looks okay, so as long as the host as a default-gateway to your wan router and http is open on that port it should work, Saying that I like to explain why cadet alian is specifying the dhcp value instead of the interface in the static
This is to cut down on unnecessary arp requests everytime a route outside your network needs to be reached. This is because your present static route is stating everything is reachable outside of your network is directly connected so each request will result in arp request being sent which could in the long term result in larger arp cache on your router and memory comsumption etc, plus you are also counting on  proxy arp being enabled on that interface which sometimes its not.
This is also applicable - ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0 dhcp
res
Paul
Please don't forget to rate any posts that have been helpful.
Thanks.
Kind Regards
Paul
@Abzal I am using DynDNS, but to make things simpler for now I am just refering to my current IP. I have had this configured on a consumer router in the past, so I know my ISP does not block 80. I will try changing the web server port, but I am also attempting to forward a few other web applications on different ports and they are not working as well.
@cadet Did as you said, still no luck. Here is my translations:
tcp 98.27.233.230:22      10.0.0.12:22          ---                   ---
To do so:
Alain
I did as you told but it is still not working. Only only thing I was unsure of was #3 no IP redirect on the WAN. Here is what I have now.
description **WAN**
ip address dhcp
ip nat enable
description **LAN**
ip nat enable
ip nat source list INSIDE_NAT_ADDR interface GigabitEthernet0/0 overload
ip nat source static tcp 10.0.0.12 80 interface GigabitEthernet0/0 80
Actually I issued no ip redirects on my WAN and it still didn't work, then I also added no ip redirects on my LAN interface and it seems to be working now.
Thanks a lot for your help Cadet Alain!
cool I didn't remember if it was needed on both sides or on WAN only.
Alain
do no ip redirect on the WAN and it should work.Did you delete old statements ?
Alain
