FR: invarp - learning from requests ?
mlopacinski
hello
According to RFC2390: " Upon receiving an InARP request, a station may put the requester's protocol address/hardware address mapping into its ARP cache as it would any ARP request."
If i have R1,R2,R3 with R1 as the hub, and i will configure:
- on R2 static mapping to R3
- on R3 static mapping to R2
- on R1 inverse arp
R1 after receiving LMI will send inverse arp request to R2 and R3 which will respond to this packet. The question is: will R2 and R3 add dynamic mapping for that DLCI/IP received in this inverse-arp request ?
Thanx
Peter Paluch
On Cisco routers, they will. The Cisco routers learn also by receiving requests, not just by receiving replies.
However, this is an implementation dependent behavior, I believe. The RFC clearly does not require that FR DTE devices learn InverseARP mappings also by requests. I can imagine a more naive (or perhaps, more strict) implementation that learns only using replies.
Best regards,
Peter
Peter Paluch
Best regards,
Peter
