Frag Table Overflow
Ricky S
Level 3
Level 3
Hi folks, I have a router that keeps having it's frag table buffer fill up quite rapidly. This router is located at one of our central offices that a lot of other offices connect to via IPSEC VPN tunnels (DMVPN). I raised the bar to 1024 however it still fills up
ip virtual-reassembly in timeout 32 max-fragments 32 max-reassemblies 1024
All routers have an MTU on their outside physical interface of 1492 bytes. All tunnel interfaces are set at 1400 to 1420 bytes MTU.
Is there a way to find out where majority of fragments are coming from? As I have a feeling this is causing an issue where right after a fresh reload I can ping this router with 1500 Byte ping packets but soon after it starts to drop these pings. Only thing I notice at that time is frag table overflow in the log.
Please advise.
paolo bevilacqua
Just disable virtual reassembly. It is just source of trouble.
paolo bevilacqua
Thanks Paolo. That did help a bit but I'm still experiencing packet loss. I just posted another long question in the forum, perhaps you can take a look at that and advise please?
https://supportforums.cisco.com/message/4088971#4088971
