Fragmentation - MTU size - within Core
Terence Payet
All,
This might be a stupid a question, but just wanted some clarifications on the above subject.
What is the recommended mtu size inside an ISP core.
If there's no recommended settings, what do you guys suggests. Do you recommend increasing the default mtu size?
Thanks in advance,
Terence
LA-Engineer
If its just IP on top of ethernet all the way through, I don't see why you shouldn't use the default 1500.
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of   the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
An ISP core?  If Ethernet, probably 1500 unless you want to be able to support jumbo Ethernet (which would probably be a good long term approach).
