frame ds3 configuration
a.mir
All,
we have a DS3 Frame circuit of 30 Meg port with a 6 meg cir. I am planning to use a 2811 with a NM-1T3 card,I need some help in confirming the configuration of the controller card.I am thinking i wont have to change anything in under the controller T3 interface.The only configuration will be under the serial associated with controller? Could any one please provide the configuration parameter for this kind of circuit assuming any DLCI number. Thanks for your help in advance
kamlesh.sharma
Level 3
Level 3
I think you need to consider these 4 command to start working with your DS3 card.
card type t3 1
controller T3 1/0
clock source line
cablelength 250
Thanks for your help.
