ISDN connection with Console Port
sandipandutta77
Can u help me how to configure isdn with router console port.
I will be grateful if u help me out...
Sandipan Dutta
ankurbhasin
Level 9
Level 9
Hi Sandipan,
I am not sure why you are pointing on router console port cause even if you access the router via console port ot telnet or whatever means configuration will remain same.
Have a look at this link to configure ISDN
http://www.cisco.com/univercd/cc/td/doc/product/software/ios11/cbook/cisdn.htm
Ankur
i want to configure the console port as a back up line for isdn apart from isdn actual bri port.
Sandipan Dutta
hello sandipan
The console port can be configured to behave as an auxiliary port (virtual AUX supports modem control for dial backup)
use :
Router(config)# line con0
Router(config-line)# modem enable
cisand
