frame-relay advance qos question?!
jiangyixiao
I have two question about qos on frame-relay:
1)If your have one frame interface, the interface queue depth exceeds 1000 packets, so adaptive rate slow down to 64K
2)If your frame interface congestioned,so you notify your peer slow down sending rate( do not use BECN/FECN)
How can satisfied above requirement?! thanks!
smahbub
Level 6
Level 6
The only way is to shape the flow of packets using shaping and compressing.
http://www.cisco.com/en/US/tech/tk652/tk698/technologies_tech_note09186a00800d6788.shtml
