Frame Relay and DCE
Muhammad Haseeb
If we are trying to use frame realy what mediums we can use with DCE for communication , Leased line , DSL or Cable . ? Please help.....
vmiller
Level 7
Level 7
Frame-relay is a leased line based technology, both for private line (you order, you worry) and MPLS VPNS. (you order, the carrier issupposed to worry).
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
As Vmiller notes, you normally use serial port leased lines for frame-relay, however unlike end-to-end (i.e. between your sites) lease lines, you only lease a line to the nearest frame-relay pop.
Often the lease lines can be obtained and used with frame-relay as fractional T1/E1, full T1/E1, MLPPP T1/E1, fractional T3/E3 or full T3/E3.  Faster than T3/E3 you normally would look to use a technology newer than frame-relay.
