Frame Relay Configuration
rohit.kulkarni
Config.:
R1---IGX -----IGX----R2
R1 7206 Router connected to IGX 8430 at IND and IGX 8430 Connected to IGX 8430 over IPLC at US and it connected to R2 Router 7206.
I've 2 FR configured on R1 s2/1.1 n s2/1.2 for 2 processes.
|-172.x.x.1---| 172.x.x.2
R1--------------IGX-----IGX(US)---R2
|-192.x.x.1---| 192.x.x.2
R1-S2/1.1-172.x.x.1
S2/1.2-192..x.x.1
I am implementing new Back link from IND to US, what should be the config.,so that I 'll ger reduendency in either case the link fails?
9 Replies 9
royalblues
Level 10
Level 10
create another FRL between US and India and congiure the 2nd link to kick in when the first fails.
You can use floating static routes or manipulate protocol metrics.
Narayan
Thanks narayan but I've 2 FRL between IND and US and already confiured ,if one failed the 2nd link would kick.
However, I implemented 3rd FRL ,now What I want is my traffic should flow from all 3 links and I'll configureon both the routers accordingly But if any links fails ,traffic shuld switch to another link.Static routes with metrics will be there.
I'd like to know the advantages and disadvantages of this and if i could configure on another way.So that i can explain it to client.
Try building MLPPoFR i.e multilink
i have the configuration running and it works fine .. below is a config example for one side
interface Multilink1
ip address
keepalive 1
ppp multilink
ppp multilink group 1
interface Serial0/0/0:0
bandwidth 1536
no ip address
encapsulation frame-relay
load-interval 30
keepalive 1
frame-relay lmi-type ansi
interface Serial0/0/0:0.1 point-to-point
keepalive 1
no cdp enable
frame-relay interface-dlci 642 ppp Virtual-Template1
interface Serial0/1/0:0
bandwidth 1536
no ip address
keepalive 1
interface Serial0/1/0:0.1 point-to-point
keepalive 1
no cdp enable
frame-relay interface-dlci 641 ppp Virtual-Template2
interface Virtual-Template1
bandwidth 1536
no ip address
keepalive 1
ppp multilink
interface Virtual-Template2
bandwidth 1536
no ip address
keepalive 1
ppp multilink
do a similar configuration for the 3rd link
Narayan
oh!that's good.Let me know one thing that If my any links fails than traffic would switch to another link and IF my already configured links like i mentioned in config..will all the traffic will shift to 3rd link.
I configured static routes for all with the 3rd links US routers IP add and given metric of 10.
Is that okay? and kindly let me knw the above i asked u and advantages and disadvantages as well.
Thanks in advance.
The above scenario which i posted was for multilink in which all links are active and the traffic will be loadbalanced. if any one of the link fails entire traffic will be taken care by the other link.
If you want your links to be active/standby then multilink is not the way for you. THe floating static routes which you have configured are good to go.
If you can post your config, we can suggest some fine tuning.
HTH, rate if it does
Narayan
Hi! narayan,
I tired but IGX dosen't support ppp and my both end routers connected to IGX.
How should i design the network for 3rd link or for all the 2 links.I am lookin for a solution with advantages and disadvantages.
Or the solution in which i should configure 3rd link and give static routes of metric 10.I meant, like present config Route ,I'll put 2 more route for the same route and give IP address of the destination address for other 2 links and metric 10.
Plz suggest.
Thnanks
you might use frame forwarding, as this does not look for FR specifics in the IGX.
The other option is to use 3 point-to-point subinterfaces with a FR PVC each on the router and static routes. Example:
interface Serial2/1
interface Serial2/1.1
ip address 10.1.1.1 255.255.255.252
frame-relay interface-dlci 100
interface Serial2/1.2
ip address 10.1.2.1 255.255.255.252
frame-relay interface-dlci 200
interface Serial3/0
interface Serial3/0.3
ip address 10.1.3.1 255.255.255.252
frame-relay interface-dlci 300
ip route 192.168.0.0 255.255.0.0 10.1.1.2 Serial2/1.1
ip route 192.168.0.0 255.255.0.0 10.1.2.2 Serial2/1.2
ip route 192.168.0.0 255.255.0.0 10.1.3.2 Serial3/0.3
This would enable load sharing over the 3 FR PVCs. If one PVC goes down (enable LMI across the port!) the remaining PVCs would take the traffic.
Hope this helps! Please rate all posts.
Regards, Martin
Hi!Martin,
Thanks as I suggested my first solution the same way.I am lookin for some other,
My current config is:
interface Tunnel1
no ip address
interface FastEthernet0/0
*** Pix Firewall***
ip address 172.2x.x.x 255.255.2x.240
duplex auto
speed auto
no cdp enable
interface FastEthernet0/1
description ***Connected to Core ****
ip address 172.2x.x.x 255.255.255.0
no ip proxy-arp
shutdown
duplex auto
speed auto
no cdp enable
interface Serial1/0
no ip address
no ip redirects
no ip mroute-cache
load-interval 30
shutdown
serial restart_delay 0
no cdp enable
interface Serial1/1
description ***Process Over a.b.200***
ip address 172.2y.x.x 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
no ip mroute-cache
load-interval 30
ntp disable
no fair-queue
interface Serial1/2
no ip address
shutdown
no cdp enable
interface Serial1/3
no ip address
no keepalive
shutdown
no cdp enable
interface Serial2/0
no ip address
shutdown
no cdp enable
interface Serial2/1
description *** Link to US router over IPLC on Port xx.7***
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
no ip mroute-cache
load-interval 30
ntp disable
no fair-queue
interface Serial2/1.1 point-to-point
description ***process ind Over a.b.100***
ip address 192.168.x.x 255.255.x.252
no ip redirects
no ip unreachables
ip accounting output-packets
no cdp enable
crypto map ADSEPIC
interface Serial2/1.2 point-to-point
description " *****Process2 over a.b.200 ***** "
ip address 172.2x.x.x 255.255.x.252
no ip unreachables
shutdown
no cdp enable
interface Serial2/2
no ip address
shutdown
no cdp enable
interface Serial2/3
no ip address
shutdown
no cdp enable
ip classless
ip route 10.x.x.x 255.255.255.255 192.168.x.x
ip route 10.x.x.x 255.255.255.255 192.168.x.y
ip route 10.x.x.x 255.255.255.255 172.2a.x.y
ip flow-export source Serial1/1
ip flow-export version 5
ip flow-export destination 172.a.b.c aabc
no ip http server
ip pim bidir-enable
If u can suggest anything else in this config.
then I did not understand your requirements.
The suggested setup will provide load sharing across all 3 links and also provide redundancy, i.e. all links, which are up will be used for load sharing.
If this does not meet your requirements, what is missing?
Regards, Martin
