Frame Relay End-to-End
a.hajhamad
Level 4
Level 4
I'm configuring End-to-End keepalive for two frame relay ends.
The config at the both ends as follows:
map-class frame-relay test
frame-relay end-to-end keepalive mode bidirectional
interface serial 0/0/0
frame-relay class test
HDQ-R2#show frame-relay end-to-end keepalive
End-to-end Keepalive Statistics for Interface Serial0/0/0 (Frame Relay DTE)
DLCI = 108, DLCI USAGE = LOCAL, VC STATUS = ACTIVE (EEK UP)
SEND SIDE STATISTICS
Send Sequence Number: 21, Receive Sequence Number: 22
Configured Event Window: 3, Configured Error Threshold: 2
Total Observed Events: 24, Total Observed Errors: 0
Monitored Events: 3, Monitored Errors: 0
Successive Successes: 3, End-to-end VC Status: UP
RECEIVE SIDE STATISTICS
Send Sequence Number: 21, Receive Sequence Number: 20
Total Observed Events: 23, Total Observed Errors: 0
My question, when i shutdown one of the both ends, the other end interface status is still UP UP, why?
Thanks in advance
Abd Alqader
11 Replies 11
bangkydotnet
--edit: sorry posted in wrong thread, please delete this post--
Kevin Dorrell
Level 10
Level 10
Did you set it up at both ends? If one end is birdirectional, then the other end must be too. The symtom you are describing sounds as if you have bidirectional on this end and passive-reply at the other end.
http://www.cisco.com/univercd/cc/td/doc/product/software/ios124/124cr/hwan_r/wan_f1h.htm#wp1072196
Also, I presume these DLCI are on the physical interface, and the frame-relay class is also on the physical.
Kevin Dorrell
Luxembourg
The ends are with bidirectional.
interface Serial0/0/0
ip address 192.168.1.122 255.255.255.252
encapsulation frame-relay
frame-relay interface-dlci 108
frame-relay lmi-type ansi
end
The other end:
interface Serial0/0/0.108 point-to-point
ip address 192.168.1.121 255.255.255.252
load-interval 30
end
One of the two ends is not a physical interface. Does is it work?
The above mentioned config will work fine without any issue.
Nagendra
Why when one of the two ends is down, the other end stills UP, UP?
Thanks in advance
Abd Alqader
Please configure the end that is using main interface, with a subinterface just like the other one.
When end A is down, end B is still up.
If end B is down, is end A still up?
If you get diffreent results in different directions, which end is which?
Kevin Dorrell
Luxembourg
Hi Kevin,
Yes, when A is shut down, B is still UP. and vise versa!
By the way, i solved this issue by enabling the dynamic routing protocol btw. the two ends EIGRP. and route the traffic to loop back interface "advertsied" to the other end.
But if you have any comments about keep alive it will be helpful since i need also to know what is the problem
Thanks in advance
Abd Alqader
As I mentioned before, please use only point-to-point subinterface to configure this feature.
Point-to-Point subinterfaces from the both sides?
Yes. Beside end-to-end keepalives, you should not have one side configure on main interface (that with FR becomes multipoint implicitly).
Let us know and don't forget to rate useful posts!
