Frame Relay Help
Peter Nugent
Guys just starting CCNP study setup my lab and cant seem to sort frame relay out!
It seems trickier than I remember
I have a 2522 with two 2501 and a 2610. it looks likonly half the interfaces/routes are coming up configs are below
2522 config
interface Serial0
description **** DCE TO RTR 1 ****
no ip address
no ip directed-broadcast
encapsulation frame-relay
clockrate 64000
frame-relay lmi-type ansi
frame-relay intf-type dce
frame-relay route 102 interface Serial1 201
frame-relay route 103 interface Serial2 301
interface Serial1
description **** DCE to RTR 2 ****
no ip address
clockrate 64000
frame-relay route 201 interface Serial0 102
frame-relay route 203 interface Serial2 302
interface Serial2
description **** DCE to RTR 3 ****
no ip address
clockrate 64000
frame-relay route 301 interface Serial0 103
frame-relay route 302 interface Serial1 203
FRAME_CORE_ROUTER#sh frame-relay route
Input Intf      Input Dlci      Output Intf     Output Dlci     Status
Serial0         102             Serial1         201             inactive
Serial0         103             Serial2         301             active
Serial1         201             Serial0         102             inactive
Serial1         203             Serial2         302             active
Serial2         301             Serial0         103             inactive
Serial2         302             Serial1         203             active
2501 config
interface Serial0
ip address 10.1.0.1 255.255.255.240
logging event subif-link-status
logging event dlci-status-change
frame-relay map ip 10.1.0.2 102 broadcast
frame-relay map ip 10.1.0.3 103 broadcast
2610 config
interface Serial0/0
ip address 10.1.0.3 255.255.255.240
frame-relay map ip 10.1.0.1 301 broadcast
frame-relay map ip 10.1.0.2 302 broadcast
Router#sh fr map
Serial0/0 (up): ip 10.1.0.1 dlci 301(0x12D,0x48D0), static,
              broadcast,
              CISCO, status defined, inactive
Serial0/0 (up): ip 10.1.0.2 dlci 302(0x12E,0x48E0), static,
              broadcast,
              CISCO, status defined, active
Router#sh fr pvc
PVC Statistics for interface Serial0/0 (Frame Relay DTE)
              Active     Inactive      Deleted       Static
  Local          1            1            0            0
  Switched       0            0            0            0
  Unused         0            0            0            0
DLCI = 301, DLCI USAGE = LOCAL, PVC STATUS = INACTIVE, INTERFACE = Serial0/0
  input pkts 0             output pkts 0            in bytes 0
  out bytes 0              dropped pkts 0           in FECN pkts 0
  in BECN pkts 0           out FECN pkts 0          out BECN pkts 0
  in DE pkts 0             out DE pkts 0
  out bcast pkts 0         out bcast bytes 0
  pvc create time 02:07:19, last time pvc status changed 00:14:19
DLCI = 302, DLCI USAGE = LOCAL, PVC STATUS = ACTIVE, INTERFACE = Serial0/0
  input pkts 65            output pkts 65           in bytes 6760
  out bytes 6760           dropped pkts 0           in FECN pkts 0
  pvc create time 02:06:42, last time pvc status changed 00:14:38
Giuseppe Larosa
Hello Pete,
are you using real devices or dynamips?
your configuration looks like correct.
is the global command
frame-relay switching
present?
Hope to help
Giuseppe
Ah well I originally configured this then it wasnt working, I tried with and without the global farame-relay switching command on the 2501s etc as I was reading various ways to implement FR and trying some troubleshooting.
I now think it may be a fauty DCE/DTE cable so have some new ones on otder as I am adding significantly to this very old lab.
