frame-relay mulitpoint configuration
folderman
hi all,
i am new to frame-relay, if i have a testing network like:
R1(s0) -- (s0)R2(s2) -- (s0) R3
(s0)
R4
* R4 is connected to R2. seems there is alignment problem
i would like to ask how can i configure all 4 routers (R2 is working as frame relay switch) so that R1, R3 and R4 can be communicated.
PS. Is it possible to configure all R1, R3 and R4 be point-to-multipoint?
thanks!
rgds,
kennethl
Kevin Dorrell
Level 10
Level 10
If R2 is acting as a frame-relay switch, then it doesn't really enter into the topology on the same way as the other routers - is it merely a network. If you wanted, you could have a full mesh; that is, create PVCs R1<->R3, R1<->R4, R3<->R4. And, yes, you could configuure each of those routers as a point-to-multipoint. Alternatively, you could create two point-to-point subinterfaces on each of the routers R1, R3, R4, one subinterface for each PVC.
Here are some useful documents to read, and a couple of pointers to source other goodstuff:
http://www.cisco.com/warp/public/125/fr_switching.pdf
http://www.cisco.com/warp/public/125/15.pdf
http://www.cisco.com/warp/public/125/16.pdf
http://www.cisco.com/en/US/tech/tk713/tk237/tech_configuration_examples_list.html
http://www.cisco.com/en/US/tech/tk713/tk237/tsd_technology_support_protocol_home.html
Hope this helps.
Kevin Dorrell
Luxembourg
