Frame-relay network with floating route
feroz syed
Level 3
Level 3
hi,
i have this frame relay network running rip protocol and aslo have a static route directly connect to R3 from R1, now the problem is when i close serial interface connected to frame-relay switchi lose connectivity from 192.168.1.0 network.
Here is my output files
R1#sh running-config
Building configuration...
Current configuration : 1844 bytes
upgrade fpd auto
version 12.4
hostname R1
boot-start-marker
boot-end-marker
logging message-counter syslog
no aaa new-model
ip source-route
no ip icmp rate-limit unreachable
ip cef
no ip domain lookup
no ipv6 cef
archive
log config
  hidekeys
ip tcp synwait-time 5
interface Loopback1
ip address 1.1.1.1 255.255.255.255
interface FastEthernet0/0
no ip address
shutdown
duplex half
interface Serial1/0
encapsulation frame-relay
shutdown
serial restart-delay 0
frame-relay map ip 192.168.1.3 103 broadcast
frame-relay map ip 192.168.1.2 102 broadcast
interface Serial1/1
ip address 210.1.1.1 255.255.255.0
interface Serial1/2
no ip address
shutdown
interface Serial1/3
no ip address
shutdown
interface Serial1/4
no ip address
shutdown
interface Serial1/5
no ip address
shutdown
interface Serial1/6
no ip address
shutdown
interface Serial1/7
no ip address
shutdown
router rip
version 2
network 172.12.0.0
network 192.168.1.0
network 210.1.1.0
no auto-summary
ip forward-protocol nd
ip route 2.2.2.2 255.255.255.255 192.168.1.2
ip route 3.3.3.3 255.255.255.255 192.168.1.3
no ip http server
end
R2#sh running-config
Current configuration : 1819 bytes
upgrade fpd auto
version 12.4
hostname R2
boot-start-marker
boot-end-marker
no aaa new-model
ip source-route
ip cef
no ip domain lookup
no ipv6 cef
  archive
log config
  hidekeys
interface Loopback1
ip address 2.2.2.2 255.255.255.255
ip address 172.12.23.1 255.255.255.224
duplex half
interface Serial1/0
ip address 192.168.1.2 255.255.255.0
frame-relay map ip 192.168.1.3 201 broadcast
frame-relay map ip 192.168.1.1 201 broadcast
interface Serial1/1
no ip address
shutdown
interface Serial1/2
no ip address
shutdown
interface Serial1/3
no ip address
shutdown
interface Serial1/4
no ip address
shutdown
interface Serial1/5
no ip address
shutdown
interface Serial1/6
no ip address
shutdown
interface Serial1/7
no ip address
shutdown
router rip
version 2
network 172.12.0.0
network 192.168.1.0
no auto-summary
ip route 1.1.1.1 255.255.255.255 192.168.1.1
ip route 3.3.3.3 255.255.255.255 192.168.1.1
no ip http server
no ip http secure-server
R3#sh running-conf
Current configuration : 1849 bytes
upgrade fpd auto
version 12.4
hostname R3
boot-start-marker
boot-end-marker
no aaa new-model
ip source-route
ip cef
no ip domain lookup
no ipv6 cef
archive
log config
  hidekeys
interface Loopback1
ip address 3.3.3.3 255.255.255.255
ip address 172.12.23.2 255.255.255.224
duplex half
interface Serial1/0
ip address 192.168.1.3 255.255.255.0
frame-relay map ip 192.168.1.2 301 broadcast
frame-relay map ip 192.168.1.1 301 broadcast
interface Serial1/1
ip address 210.1.1.2 255.255.255.0
interface Serial1/2
no ip address
shutdown
interface Serial1/3
no ip address
shutdown
interface Serial1/4
no ip address
shutdown
interface Serial1/5
no ip address
shutdown
interface Serial1/6
no ip address
shutdown
interface Serial1/7
no ip address
shutdown
router rip
version 2
network 172.12.0.0
network 192.168.1.0
network 210.1.1.0
no auto-summary
ip route 2.2.2.2 255.255.255.255 192.168.1.1
no ip http server
R1#sh ip route
Gateway of last resort is not set
     1.0.0.0/32 is subnetted, 1 subnets
C       1.1.1.1 is directly connected, Loopback1
     2.0.0.0/32 is subnetted, 1 subnets
S       2.2.2.2 [1/0] via 192.168.1.2
     3.0.0.0/32 is subnetted, 1 subnets
S       3.3.3.3 [1/0] via 192.168.1.3
     172.12.0.0/27 is subnetted, 1 subnets
R       172.12.23.0 [120/1] via 210.1.1.2, 00:00:15, Serial1/1
R    192.168.1.0/24 [120/1] via 210.1.1.2, 00:00:15, Serial1/1
C    210.1.1.0/24 is directly connected, Serial1/1
R2#sh ip route
S       1.1.1.1 [1/0] via 192.168.1.1
C       2.2.2.2 is directly connected, Loopback1
S       3.3.3.3 [1/0] via 192.168.1.1
C       172.12.23.0 is directly connected, FastEthernet0/0
C    192.168.1.0/24 is directly connected, Serial1/0
R    210.1.1.0/24 [120/1] via 172.12.23.2, 00:00:19, FastEthernet0/0
R3#sh ip route
S       2.2.2.2 [1/0] via 192.168.1.1
C       3.3.3.3 is directly connected, Loopback1
Hello
"Router 1 has learned rip routes via R3 and R2 so router R1 know how to reach 192.168.1.2 and 172.12.23.2 destinations. R1 send rip updates via serial interface 1/1 (210.1.1.1)"
- Wrong
R1 has a valid next hop to reach R3 loopback because of the rip routes it learned from r3 via ser1/1 which included 192.168.1.0/24 and the subnet between r2&r3
However r2 k r3 still thinks to get to r1 loopback they need to go via ser0/1 and because these two rtrs are not aware 192.168 1.0/24 is not available due to their ser0/1 interfaces still being up this subnet is still being advertised are directly connected by both of them
This is not the case for r1 as its ser0/1 interface is down so the 192.168.10/24 isnt advertised in it rib table as directly connected and is now learned via rip over ser1/1
Res
Paul
Kind Regards
Paul
9 Replies 9
cadet alain
I don't see any floating route here as all your static routes have an AD of 1 which is the default, furthermure if you want to do failover then your static routes must be using the HDLC link between R1 and R3 and be for the same prefix advertised by your routing protocol.
What are you trying to achieve ? ping the loopback on R1 from R2 or R3 not using the frame-relay cloud when the frame-relay interface of R1 comes down ? if this is what you want then I'll post the configs to achieve this.
Alain
well forget about the floating route, why i can't ping from network 210.1.1.1 to 192.168.1.2 or 1.3. but all loopback ping each other.
So you're pinging R2 and R3 frame-relay IP sourcing from the hdlc link on R1 and it is failing but pinging the loopbacks on R2 and R3 from the same source is succeeding ?
Alain
Sorry by mistake my prevoius post wrongly said tht all loopback pinging each other, now router 1 has ping connectivity to 3.3.3.3 and 210.1.1.2 and 172.12.23.2 and router 2 has ping connectivity to 172.12.23.2 and 210.1.1.1. and router 3 has only ping connectivity to 210.1.1.1
R1#ping 192.168.1.2
Sending 5, 100-byte ICMP Echos to 192.168.1.2, timeout is 2 seconds:
Success rate is 0 percent (0/2)
R1#ping 2.2.2.2
Sending 5, 100-byte ICMP Echos to 2.2.2.2, timeout is 2 seconds:
Success rate is 0 percent (0/3)
R1#ping 3.3.3.3
Sending 5, 100-byte ICMP Echos to 3.3.3.3, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 16/32/56 ms
R3#ping 2.2.2.2
Success rate is 0 percent (0/5)
R3#ping 1.1.1.1
Sending 5, 100-byte ICMP Echos to 1.1.1.1, timeout is 2 seconds:
R3#ping 192.168.1.2
R3#ping 2.2.2.2
R3#ping 210.1.1.1
Sending 5, 100-byte ICMP Echos to 210.1.1.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 16/33/68 ms
R2#ping 2.2.2.2
Success rate is 100 percent (5/5), round-trip min/avg/max = 4/4/4 ms
R2#ping 3.3.3.3
R2#ping 192.168.1.3
Sending 5, 100-byte ICMP Echos to 192.168.1.3, timeout is 2 seconds:
R2#ping 210.1.1.1
Success rate is 100 percent (5/5), round-trip min/avg/max = 16/40/68 ms
Hello
The reason has been stated by Cadet Allan - the static's are still pointing to a unreachable next hop and have preference.
1) You can Advertise the loopbacks in rip  and apply ip sla tracking to the static routes
2) Have no  static and either LB between the interfaces or offset the rip routes for a desired path.
res
Paul
Please don't forget to rate any posts that have been helpful.
Thanks.
Kind Regards
Paul
okay, how am pinging from r1 ro r3 loop interface but r3 not pinging to r1 loop interface ?
Hello
Possibly spilt sh horizon is prohibiting R1 from  re-advertsing 192.168.1.0/24 back out of the same interface it  leraned that route from ( in this case ser1/1)
R3 is seeing 192.168.1.0/24 direcdtly connected via ser0/1 which is down, if you add another static on R3  pointing to ser1/1 next hop R3 would able to ping 1.1.1.1. or advertise the loopbacks via rip
R1
R3
     1.0.0.0/32is subnetted, 1 subnets
res
Paul
Thanks.
Kind Regards
Paul
sorry i didn't understand correctly, how you saying that split horizon is prohibiting ?? R1 has two interface one was shutdown manually which is directly connected to frame relay switch another directly connected to R3 via serial interface.
R1#sh ip route
Hello
- Wrong
Res
Paul
Kind Regards
Paul
