Frame-relay Problems
david foley
Hi have a Hub & Spoke Frame Relay set up, R4 - R5 & R4 - R6 are all pinging ok, But if i go R5 - R6 or R6 - R5 they are not pinging each other,
I cant get the PC which on R5 to ping R4 nor the Server on R6. I set up OSPF 1 for the Frame Links to see would this fix the problem. but with no joy. could some one tell me where i am going wrong in how i fix this problem so All Routers within Frame Relay can ping.
R4
Building configuration...
Current configuration : 951 bytes
version 12.4
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname R4
interface FastEthernet0/0
no ip address
duplex auto
speed auto
shutdown
interface FastEthernet0/1
no ip address
duplex auto
speed auto
shutdown
interface Serial0/0/0
ip address 172.190.0.6 255.255.255.252
interface Serial0/0/1
ip address 172.190.0.18 255.255.255.252
encapsulation frame-relay
frame-relay map ip 172.190.0.17 405 broadcast
frame-relay map ip 172.190.0.18 405
interface Serial0/0/1.406 point-to-point
ip address 172.190.0.22 255.255.255.252
frame-relay interface-dlci 406
interface Vlan1
no ip address
shutdown
router ospf 1
log-adjacency-changes
network 172.190.0.4 0.0.0.3 area 0
network 172.190.0.20 0.0.0.3 area 0
network 172.190.0.16 0.0.0.3 area 0
ip classless
line con 0
line vty 0 4
login
end
R5
hostname Router
ip address 172.190.0.81 255.255.255.248
duplex auto
speed auto
no ip address
duplex auto
speed auto
shutdown
no ip address
shutdown
ip address 172.190.0.17 255.255.255.252
frame-relay map ip 172.190.0.18 504 broadcast
frame-relay map ip 172.190.0.17 504
interface Vlan1
no ip address
shutdown
router ospf 1
network 172.190.0.0 0.0.0.255 area 0
ip classless
line con 0
line vty 0 4
login
end
R6
Current configuration : 805 bytes
version 12.4
hostname Router
ip address 172.190.0.73 255.255.255.248
duplex auto
speed auto
no ip address
duplex auto
speed auto
shutdown
ip address 172.190.0.21 255.255.255.252
frame-relay map ip 172.190.0.22 604 broadcast
frame-relay map ip 172.190.0.21 604
no ip address
shutdown
interface Vlan1
no ip address
shutdown
router ospf 1
ip classless
line con 0
line vty 0 4
login
end
19 Replies 19
do you want me to send the File or just Docment Shot of the Network ?
You can send the pkt file.
Alain.
ok,
here is the PT file, just if you dont have the New PT program it wont open it just seems to open only for the new PT program..
on R6 just do this:
int s0/0/0
ip ospf network point-to-point
no ip ospf priority 0
do clear ip ospf process ---> yes
Your adjacency will fulfill and your RIB will get populated and then everything should be ok.
Regards.
Alain.
Thanks very much your a life saver...
i've been pulling my hair out for the last few days and not once did it every come into my head to reset the ospf..
