FRAME RELAY ROUTER NOT LET ME ADVERTISE EIGRP ROUTES
                   I have a basic topology
R1 ---- DLCI 102 , 103
R2---- DLCI 201
R3 ----  DLCI 301
Configuration on R1
interface Loopback0
ip address 10.1.1.1 255.255.255.0
interface Loopback1
ip address 10.1.2.1 255.255.255.0
interface Loopback2
ip address 10.1.3.1 255.255.255.0
interface Serial0/0
no ip address
encapsulation frame-relay
clock rate 64000
frame-relay lmi-type cisco
interface Serial0/0.1 multipoint
ip address 172.16.124.1 255.255.255.248
frame-relay map ip 172.16.124.2 102 broadcast
frame-relay map ip 172.16.124.3 103 broadcast
router eigrp 25
network 10.1.0.0 0.0.255.255
network 172.16.0.0
no auto-summary
R1#sh frame-relay map
Serial0/0.1 (up): ip 172.16.124.2 dlci 102(0x66,0x1860), static,
              broadcast,
              CISCO, status defined, active
Serial0/0.1 (up): ip 172.16.124.3 dlci 103(0x67,0x1870), static,
              broadcast,
Configuration of R2
interface Loopback1
ip address 10.2.1.1 255.255.255.0
interface Loopback2
ip address 10.2.2.1 255.255.255.0
interface Loopback3
ip address 10.2.3.1 255.255.255.0
interface Serial0/0
ip address 172.16.124.2 255.255.255.248
clock rate 2000000
frame-relay map ip 172.16.124.1 201
router eigrp 25
network 10.2.0.0 0.0.255.255
network 172.16.0.0
no auto-summary
R2#sh frame-relay map
Serial0/0 (up): ip 172.16.124.1 dlci 201(0xC9,0x3090), static,
R2#
Configuration on R3
interface Loopback1
ip address 10.3.1.1 255.255.255.0
interface Loopback2
ip address 10.3.2.1 255.255.255.0
interface Loopback3
ip address 10.3.3.1 255.255.255.0
interface Serial0/0
ip address 172.16.124.3 255.255.255.248
clock rate 2000000
frame-relay map ip 172.16.124.1 301
router eigrp 25
network 10.3.0.0 0.0.255.255
network 172.16.0.0
auto-summary
R3#sh frame-relay map
Serial0/0 (up): ip 172.16.124.1 dlci 301(0x12D,0x48D0), static,
FR ROUTER
interface Serial0/0
no ip address
clock rate 2000000
frame-relay intf-type dce
frame-relay route 102 interface Serial0/1 201
frame-relay route 103 interface Serial0/2 301
interface Serial0/1
no ip address
clock rate 2000000
frame-relay route 201 interface Serial0/0 102
interface Serial0/2
no ip address
clock rate 2000000
frame-relay route 301 interface Serial0/0 103
R5#sh frame-relay route
Input Intf      Input Dlci      Output Intf     Output Dlci     Status
Serial0/0       102             Serial0/1       201             active
Serial0/0       103             Serial0/2       301             active
Serial0/1       201             Serial0/0       102             active
Serial0/2       301             Serial0/0       103             active
MY QUESTION IS :
I AM ABLE TO PING IP ADDRESS 172.16.0.1, 172.16.0.2,172.16.0.3 . But when i configure eigrp...it is configured properly...
My frame relay mapping is also done properly and it is active as well...
I am not able to see eigrp routes.
     172.16.0.0/29 is subnetted, 1 subnets
C       172.16.124.0 is directly connected, Serial0/0.1
     10.0.0.0/24 is subnetted, 3 subnets
C       10.1.3.0 is directly connected, Loopback2
C       10.1.2.0 is directly connected, Loopback1
C       10.1.1.0 is directly connected, Loopback0
It only shows connected routes. It does not show any routes coming from r2 and r3. I am aware about split horizon as well in this network type. but there is not need to configure that as if now. cz i am not getting routes from any of the spokes to hub router which is R1.
These are some logs whicI got from R3(SPOKE)
R3#
*Mar  1 04:45:15.382: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 25: Neighbor 172.16.124.1 (Serial0/0) is up: new adjacency
R3#
R3#
*Mar  1 04:48:19.898: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 25: Neighbor 172.16.124.1 (Serial0/0) is down: retry limit exceeded
R3#
*Mar  1 04:48:57.554: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 25: Neighbor 172.16.124.1 (Serial0/0) is up: new adjacency
IP-EIGRP neighbors for process 25
H   Address                 Interface       Hold Uptime   SRTT   RTO  Q  Seq
                                            (sec)         (ms)       Cnt Num
0   172.16.124.1            Se0/0            163 00:01:11    1  5000  1  0
Hold time is 163 ... I think it should be less then 10. After holtime expire my neighborship goes down.
No access list is configured to block hellos.
So what could be the reason that i am able to see it in neighbor table but routing table is not giving me any eigrp learnt routes.
I think FR router is creating problem. How to fix it...
THANKS IN ADVANCE :-)
2 Accepted Solutions
Giuseppe Larosa
Hello Namish,
on spoke routers R2, R3 add the broadcast keyword to the frame-relay mapping command.
This is required to correctly exchange  EIGRP hello packets that have a multicast destination.
On hub router you need to disable EIGRP split horizon also as you noted
Hope to help
Giuseppe
Praveen AR
Hello Namish,
Broadcast  keyword missing on  spoke router configurations
Giuseppe Larosa
Hello Namish,
Hope to help
Giuseppe
Praveen AR
Hello Namish,
