Frame Relay Switch
barhamgary
I have a cisco 2610 router (IOS 12.3(15)) that I am trying to configure as a frame relay switch. It has 2 T1 DSU/CSU cards. I am experiencing some difficulty in activating the 2 serial interfaces. I have attached the show run and show frame route outputs. Any help in getting the configuration correct would be greatly appreciated.
I have corrected the configuration and my frame relay switch is up and running. The following is the configuration for the frame relay switch.
FRS#sh run
Building configuration...
Current configuration : 1113 bytes
version 12.3
hostname FRS
boot-start-marker
boot-end-marker
no aaa new-model
ip subnet-zero
ip cef
no ip domain lookup
frame-relay switching
interface Ethernet0/0
ip address 192.168.1.10 255.255.255.0
half-duplex
interface Serial0/0
no ip address
encapsulation frame-relay
logging event subif-link-status
logging event dlci-status-change
fair-queue
service-module t1 clock source internal
no frame-relay inverse-arp
frame-relay intf-type dce
frame-relay route 122 interface Serial0/1 221
interface Serial0/1
no ip address
fair-queue
frame-relay route 221 interface Serial0/0 122
ip http server
ip classless
line con 0
exec-timeout 0 0
logging synchronous
line aux 0
line vty 0 4
exec-timeout 0 0
logging synchronous
login
end
FRS#
The following is the configuration for one of my frame relay spoke routers.
Vista#sh run
Current configuration : 702 bytes
version 12.3
hostname Vista
boot-start-marker
boot-end-marker
no aaa new-model
ip subnet-zero
ip cef
no ip address
shutdown
half-duplex
interface Serial0/0
no ip address
interface Serial0/1
ip address 192.168.1.4 255.255.255.0
fair-queue
frame-relay interface-dlci 221
ip http server
ip classless
line con 0
exec-timeout 0 0
logging synchronous
line aux 0
line vty 0 4
exec-timeout 0 0
logging synchronous
login
end
Vista#
Message was edited by: barhamgary
paolo bevilacqua
Also include "show version", you need enterprise IOS for FR switching.
Do not use attachments unless necessary.
Your configuration looks fine, so I don't think this is an IOS related issue (Commands won't be accepted for unsupported features)
The CE on se0/0 should have dlci 122 and the one on se 0/1 should have dlci 221. If it doesn't work, check if Layer 1 is up on both ends, then try "debug frame lmi" on the CE and the switch.
